Old 09-04-2015, 08:23 AM   #11
I will be very interested in doing this mod. as well. Unfortunately one battle at a time. lol First priority will be the issue with weights.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-04-2015, 08:37 AM   #12
15berkxl's Avatar
Joe you are going to be very busy with all these modifications once you pick up your unit lol.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 09-04-2015, 08:57 AM   #13
Wayne
You mean there are more than just these two ? Is there a whole list somewhere posted?
Joe & Lori
Old 09-04-2015, 08:59 AM   #14
silver's Avatar
I will add this mod if I ever see my coach again. Still waiting on repair.
silver is offline   Reply With Quote
Old 09-04-2015, 09:09 AM   #15
bubbles's Avatar
Originally Posted by bubbles View Post
Your steps must be Lippert (red=step power/brown=door switch). Door switch ground with door open. Will of course not work if one has Kwikee steps (door switch open with door open).
However, for those that may want to accomplish this mod on Kwikee steps it should be noted that prior to 2/99 kwikee used a NC door switch and it is still available, part number 905312000 and available from American RV Company $12.00 (and others). Probably can be mounted on existing small door switch using existing single magnet or added to doors independently. Just a thought.
Old 09-04-2015, 09:13 AM   #16
dan-nickie's Avatar
Hank and Bubbles, I had read the kwikee manual first and that is what took me so long to realize my lipert door switch went to ground when the door was open.
Once I finally figured that out it was stupid simple.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-04-2015, 12:04 PM   #17
Can anyone tell me the wiring differences between Lippert and Kwikee steps. Thanks
Harkerr is offline   Reply With Quote
Old 09-04-2015, 05:54 PM   #18
Step
Originally Posted by I-RV View Post
Thanks' Dan; I must say that you are like a dog on a bone - you eventually get the job done - LOL.
I'm attaching the Coach Step wiring for others that may be interested:
https://www.strombergcarlson.com/sto...%20Lippert.pdf
As noted earlier, if you have Kwikee Step, the door magnet circuit is different. - Hank
I am having trouble with steps changed out controller new one
When I turn off steps so they won't work while parked steps cont to work switch ok also light comes on when steps go up not out
Dkplace is offline   Reply With Quote
Old 09-04-2015, 05:57 PM   #19
Help changed out controller new one same problem switch does not stop steps from retracting when parked.kids open door too much
Also light comes on when retracted and stays on instead of other way
Old 09-04-2015, 06:00 PM   #20
How is the Kwikee circuit different. I am trying to use a Stromberg Carlson controller on Kwikee steps and not working. What do I need to change to make it work?
light, modifications
