09-03-2015, 09:50 PM
My Step Lights Mod
You Berkshire guys know a few of us were discussing how to keep the Step Lights on when the step switch was turned off.
Hank has already shown his solution by connecting the light to both the Isle and Porch light switch.
I was determined to have the lights come on and go off as the door was opened and closed. As it turns out, it was very easy wiring. Only had to splice 2 wires both located down under the steps.
I did use a strip of LEDs that I had left over from another project and left the stock original light as it was.
Here are a couple pictures and maybe a video:
LED STRIPS STUCK TO FIBERGLASS JUST ABOVE STEPS
FROM OUTSIDE
FROM INSIDE
WITH STEP SWITCH ON - STOCK LIGHT COMES ON ALSO AS STEPS COME OUT
YOUTUBE VIDEO
https://youtu.be/N7w3eoySi4o
Dan
2014 Berkshire 390RB-60
09-03-2015, 10:01 PM
marialee-Berkshire410qs
Looking Great Dan!! Say HI to Nickie for me.
09-03-2015, 10:03 PM
Thanks, & I certainly will tell Nickie you said hi.
Dan
09-03-2015, 10:33 PM
which two wires did you connect to?
09-03-2015, 10:37 PM
From the LED strip, + to the Red, - to the Brown.
Dan
09-04-2015, 05:16 AM
Looks good.
Joe & Lori
2014 Berkshire 390 RB-40
09-04-2015, 06:59 AM
Great job, Dan. Was the red and brown wires in the cable bundle going between the controller and cabin? - Hank
Gale & Hank- 2012 Berkshire 390BH
09-04-2015, 07:12 AM
Your steps must be Lippert (red=step power/brown=door switch). Door switch ground with door open. Will of course not work if one has Kwikee steps (door switch open with door open).
09-04-2015, 08:01 AM
Right. there is Red, Brown, White and Yellow in the bundle.
You probably looked at them enough to know that Red is 12v and Brown is the magnetic door switch to ground.
Dan
09-04-2015, 08:07 AM
Thanks' Dan; I must say that you are like a dog on a bone - you eventually get the job done - LOL.
I'm attaching the Coach Step wiring for others that may be interested:
https://www.strombergcarlson.com/sto...%20Lippert.pdf
As noted earlier, if you have Kwikee Step, the door magnet circuit is different. - Hank
09-04-2015, 08:23 AM
I will be very interested in doing this mod. as well. Unfortunately one battle at a time. lol First priority will be the issue with weights.
Joe & Lori
09-04-2015, 08:37 AM
Joe you are going to be very busy with all these modifications once you pick up your unit lol.
Wayne
Wayne
09-04-2015, 08:57 AM
Wayne
You mean there are more than just these two ? Is there a whole list somewhere posted?
Joe & Lori
09-04-2015, 08:59 AM
I will add this mod if I ever see my coach again. Still waiting on repair.
09-04-2015, 09:09 AM
However, for those that may want to accomplish this mod on Kwikee steps it should be noted that prior to 2/99 kwikee used a NC door switch and it is still available, part number 905312000 and available from American RV Company $12.00 (and others). Probably can be mounted on existing small door switch using existing single magnet or added to doors independently. Just a thought.
09-04-2015, 09:13 AM
Hank and Bubbles, I had read the kwikee manual first and that is what took me so long to realize my lipert door switch went to ground when the door was open.
Once I finally figured that out it was stupid simple.
Dan
09-04-2015, 12:04 PM
Can anyone tell me the wiring differences between Lippert and Kwikee steps. Thanks
09-04-2015, 05:54 PM
Step
I am having trouble with steps changed out controller new one
When I turn off steps so they won't work while parked steps cont to work switch ok also light comes on when steps go up not out
09-04-2015, 05:57 PM
Help changed out controller new one same problem switch does not stop steps from retracting when parked.kids open door too much
Also light comes on when retracted and stays on instead of other way
09-04-2015, 06:00 PM
How is the Kwikee circuit different. I am trying to use a Stromberg Carlson controller on Kwikee steps and not working. What do I need to change to make it work?
