Old 04-30-2014, 03:23 PM   #1
dontech's Avatar
Exclamation Mystery Coolant Leak
Hi All,
I could use some help with a perplexing coolant leak on my 2008 Berkshire. I posted the issue in detail at RVPics.com here. (Moderator remove the link if it is not appropriate.)
I scoured the internet for clues to solving this problem. I could not even find anything helpful about accessing the engine from the bedroom cover. We finally got it uncovered. I doubt you will find any other pictures of the engine viewed from the bedroom of your Berkshire.
After reading the post, if you have any ideas, I would appreciate hearing from you. If you don't post at RVPics, please leave me a message here or email me. Thanks for your interest.
Don
Don
W6DEJ
Turlock, CA
2015 Cardinal 3550RL Fifth Wheel
dontech is offline   Reply With Quote
Old 04-30-2014, 03:38 PM   #2
Berkshire 390QS
NO3putt's Avatar
Don, can not help with the leak, but thanks for the pictures, now I have some idea how to get the engine cover off. Good luck with leak.
NO3putt is online now   Reply With Quote
Old 04-30-2014, 03:53 PM   #3
fonzie's Avatar
If it was me I would start engine and let it warm up to operating temperature and see if that big coolant hose from the rad on the right springs a leak.
Fonzie
Old 04-30-2014, 04:30 PM   #4
NV245's Avatar
Have you tried to find a radiator pressure tester? Autozone has a loaner program, however I don't know if one is in their inventory. I hope it isn't so, but I have had a 5.9 Cummins headgasket leak without coolant/oil cross contamination. (the leak was in the thermostat area). There is also ultraviolet coolant leak dye which will glow under UV (black) light. I also hope you are using heavy duty Diesel coolant (I usually have to go to NAPA). Good luck, I'm very curious to hear the results.
NV245 is offline   Reply With Quote
Old 04-30-2014, 05:18 PM   #5
DAISY BOYKIN's Avatar
Overflow tank------------
Don,
I had the very similar leak on a automobile, Couldn't find where the antifreeze was leaking from. I did a little search on Google and found the overflow tank had a small split on the bottom of the tank. It was a seam
that would not always leak but began to get worse over time.
Just a suggestion. Also look at freeze plugs??
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-30-2014, 06:12 PM   #6
Check the weep hole below the water pump's pulley. See if you have any water leaking from there. Get yourself a decent inspection mirror & a good flashlight & start scanning around. Given how dusty the engine looks, you should be able to look for a clean trail in the dust for the trail made by the leak, if it is on the engine itself.
romeofrosty is offline   Reply With Quote
Old 04-30-2014, 06:24 PM   #7
fonzie's Avatar
Could this be a leak at top right corner of rad?
Fonzie
Old 04-30-2014, 06:31 PM   #8
puff's Avatar
Most auto parts stores now have a dye you put in the coolant and then let it warm up. It comes with a special pair of glasses and the leak shows up like a beacon. That is the easiest way to find it and fix from there.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 04-30-2014, 06:49 PM   #9
At least I now know what my engine MIGHT look like. I have the RB model and the hatch in the bathroom floor is real easy to get to...... Nothing to remove but the hatch door itself.
BUT.... I've taken out every fastener I could find, tugged like hell on the cover and it will NOT come loose. Phil, you ever had your open??
OBTW, I have nothing to contribute to your original problem... Sorry.
Boowho??
boowho is offline   Reply With Quote
Old 04-30-2014, 06:53 PM   #10
silver's Avatar
Ideas
Originally Posted by dontech View Post
Hi All,
Don
Hi Don,
Well you passed the first test and got the hatch opened. It will not be any easier the second time. Don't ask me how I know. I cut the wood down 1/4 inch and now it is much easier. I also replaces the bolts for latches. I can now get the hatch off in minutes.
On to your problem. I have read many threads here and in IRV2 talking about split plastic radiator tanks. As the fluid was coming from the top of the engine this is probably a good bet. The low co-lent sensor is in the plastic tank. Can you fill it and put pressure on the tank? A cheep pressure tester is a old bike tire cut in two, cap one end and stretch other over the tank opening. As soon as you start to pump up the tube if the tank is leaking you should know.
You can also isolate the front of the coach, all the plumbing and the heater going to the dash. Under the coach on each side of the frame at the back are T valves. One on each side. One for feed and one for return to front of coach for heater. They were original yellow. You could shut these to be sure the problem is isolated to the engine and not heater hoses going to the front of the coach.
I hope some of this helps.
silver is offline   Reply With Quote
leak
