Old 06-27-2015, 07:43 PM   #1
Need a little help with water smell
In early spring I ran bleach through the entire plumbing of our 2011 390BH including the hot water heater. We have taken 2 short weekend trips and everything was fine with the water. Now we are up in Mount Rushmore for a week and turned on the hot water and it smells like rotten eggs. The cold water smells fresh it is just the hot water. How do I fix this there is no way the wife is going to use the public showers.
Also could someone tell me what size socket is used to remove the drain plug of the water heater.
I will have to check the responses in the morning since the campground we are in only has WIFI at the office and not the whole campground
Thanks for your help in advance
csichoice is offline   Reply With Quote
Old 06-27-2015, 08:01 PM   #2
mark0224's Avatar
The rotten egg smell is sulfur the park where you filled up probably has some sulfur in their water. The longer it sits the more you will notice it and when its heated it will be more noticeable. Drain your tanks including the HW, refill the system with water and chlorine run some thorough the system including HW. Let it sit overnight then light HW next day. It should go away after this but if not it will in time.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-27-2015, 08:06 PM   #3
If its the same Suburban tank I have, the drain plug/anode rod is 1and 1/16
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 06-27-2015, 08:09 PM   #4
B and B's Avatar
You may want to drain the low point drains again. I have had an issue with our park model and the washer connection, antifreeze mixing with chlorinated park water causes similar smell.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-28-2015, 05:59 AM   #5
90% of the time it is bacteria in the water heater and it puts out a bad sulfur smell. It is not harmful. Google it and you will find what to do. I had the same problem and put a mix of bleach and water (can't remember the ratio) and let it stand for 24 hours. It will get rid of it. RV stores also have a product you can use. Flush all hot water lines after.
harderd is offline   Reply With Quote
Old 06-28-2015, 06:04 AM   #6
Herk7769's Avatar
The manual is clear on "odor"; sanitize your system (not just the water tank).
Name:	Odor From HWH.jpg
HAM CALLSIGN - KC3FFW
Old 06-28-2015, 06:53 AM   #7
crunchman12001's Avatar
How long did the water sit in your system since the short trips in spring? If I won't be in the camper for a couple weeks, I drain everything so the water does not ferment and get nasty smelling.
crunchman
2015 F-250 FX4
Old 06-28-2015, 07:16 AM   #8
i use Taste Pure from walmart in the fresh water tank , maybe drain the HW tank before he mix gets there
Big Bill is offline   Reply With Quote
Old 06-28-2015, 07:23 AM   #9
Georgia Frog Rally 2018
aceinspp's Avatar
After returning from every trip I drain the HW tank, and drain all other lines using air. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-28-2015, 07:34 AM   #10
kdot's Avatar
In all probability, the water heater anode takes a 1-1/16 socket. First, release any pressure in the heater by pulling the release valve, then screw the anode out. You may need an extension on hour wrench. After you drain the heater, put a little teflon tape on the anode threads to help seal it when you screw the anode back in. DON"T reef on it; just snug it up! Good luck.
Kent
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
water
