Closed Thread
Old 02-27-2016, 05:13 PM   #41
2014 360 QL
po 185's Avatar
well you are right,, just use the tables,,,, they work!
2014 360 ql
po 185 is offline
Old 02-27-2016, 05:33 PM   #42
NV245's Avatar
Settng tire pressure to load is a matter of getting the proper tire to road contact patch. The reason those who have used the tire manufacturer's tables feel a more stable ride is a tire overinflated for load has less contact with the road surface, actually overheating at the contact area, causing higher center tread wear and less side to side grip.
NV245 is offline
Old 02-27-2016, 05:57 PM   #43
silver's Avatar
Originally Posted by TwiceTheIce View Post
I have weighed the coach, done the math and checked the Michelin pressure chart, but it doesn't seem right. Please confirm that I am correct or point out my error. Thanks.
Michelin 275/80R22.5 H XZA3 tires.
150 Gallons of Fuel
Fresh Water Full
Fridge Full
Liquor cabinet Full
Steer axle: 12800#
Drive Axle: 15020#
Tag Axle: 7380#
Total 35200#
When I check the Michelin chart, I get:
110 psi on Steer
75 psi on Drive
75 psi on Tag.
I know it is a big difference on load per tire from the front to the back, but it just seems like a big difference in pressure on front and rear.
PLEASE NO GUESSING. PLEASE NO OPINIONS. JUST PURE KNOWLEDGE.
Just increase PIS on rear tires by 5 PSI and you should be good per info from Michelin manuals. See attached. What about it guys?
ID:	100596   Click image for larger version
silver is offline
Old 02-27-2016, 07:58 PM   #44
asquared's Avatar
Another site team cleanup has been done. This is the last warning before this thread gets closed. Keep it civil.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline
Old 02-27-2016, 09:16 PM   #45
Silver, this is exactly what I did (except for adding the 5psi to the 75psi). In my op, I just wanted confirmation, because 75 psi sounded low. To all of you with knowledge and the willingness to share it--Thank you.
For those who don't know and don't care that they don't know--there are none so blind as those who refuse to see.
Revised solution: 110 for steer and 85 for everything else. I just can't bring myself to go to 75 or 80 (at least until the Michelin man calls on Monday).
2016 Berkshire XLT 43a
TwiceTheIce is offline
Old 02-27-2016, 09:17 PM   #46
Ron that sounds like the best. Hope you are enjoying that new Berk extra long.
Phil57 is offline
Old 02-27-2016, 10:19 PM   #47
asquared's Avatar
Another good thread closed because some members are unable to follow the rules and stay civil and on topic. I do hope the OP has enough info to answer the question.
2014 Sabre 34REQS-6
asquared is offline
Closed Thread
pressure, tire
