Closed Thread
Old 02-26-2016, 03:59 PM   #1
Need a math teacher for tire pressure confirmation
I have weighed the coach, done the math and checked the Michelin pressure chart, but it doesn't seem right. Please confirm that I am correct or point out my error. Thanks.
Michelin 275/80R22.5 H XZA3 tires.
150 Gallons of Fuel
Fresh Water Full
Fridge Full
Liquor cabinet Full
Steer axle: 12800#
Drive Axle: 15020#
Tag Axle: 7380#
Total 35200#
When I check the Michelin chart, I get:
110 psi on Steer
75 psi on Drive
75 psi on Tag.
I know it is a big difference on load per tire from the front to the back, but it just seems like a big difference in pressure on front and rear.
PLEASE NO GUESSING. PLEASE NO OPINIONS. JUST PURE KNOWLEDGE.
2016 Berkshire XLT 43a
TwiceTheIce is offline
Old 02-26-2016, 04:09 PM   #2
I'm assuming the rears are dually tires on each axle? If so the load is spread over many more tires than the steering ones. That would both make sense and give more sidewall flex and smoother ride in the rear.
Byron in TX is offline
Old 02-26-2016, 05:40 PM   #3
Blackrock's Avatar
The sidewall of the tire tells the true story. For optimum tread wear and tire life run your tires at 110 front 90 on the rear. These are TRUCK tires and are to be treated as such. If you run a tire that size at 75psi you are basically 60% deflated. Running to low of pressure will cause overheating leading to early tire failure.
This ain't a Cadillac so don't expect a Cadillac ride.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline
Old 02-26-2016, 06:06 PM   #4
Crusadernoob's Avatar
Dual's always run less than a single, I would run what is rated by the tire manufacturer for the weight you have on them. I always add a little more for a margin factor. I don't just put in the max pressure just to run max pressure.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline
Old 02-26-2016, 07:57 PM   #5
Campin Cajun's Avatar
This absolutely the wrong advice.
2013 Berkshire 390BH
Campin Cajun is offline
Old 02-26-2016, 08:01 PM   #6
Twice, I don't have a tag axle but I run less pressure in my dual rears than I do in my steer tires. If you are getting these pressures from the Michelin tire chart then I would say you are correct.
Old 02-26-2016, 08:31 PM   #7
NV245's Avatar
I share Campin Cajun's opinion, and would add that you may want to consider left and right weights and base pressure on the heavier side of the axle. Tire pressures should be the same on both sides of the axle, but that pressure should relate to the heaviest side.
NV245 is offline
Old 02-27-2016, 07:04 AM   #8
Yes, exactly!
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline
Old 02-27-2016, 07:14 AM   #9
Blackrock's Avatar
Welp, looks like I got Flamed pretty good on this one. I only been in the heavy truck fleet repair business for thirty plus years so I guess I need to bow out of any tire related issues on this forum.
Old 02-27-2016, 08:15 AM   #10
dan-nickie's Avatar
Seems many from the heavy truck world recommend max pressure in all tires. Motor homes are different thing and the manufacturers sometimes recommend adjusting the tire pressure based on the way to give the best ride.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline
Closed Thread
pressure, tire
