I must a loose ground on the dash components. I'll be driving down the road all of a sudden the dash air shuts down, radio, fans, seat, wipers, mirrors, all shut down. Anyone have any idea what's causing this? I called FL they said it's the manufacturer have a call in with FR no response as of yet. I figure someone here might be able to steer me in the right direction. Thanks for any help Jim
I would check the plug connections One of the connectors is probably loose under the dash or in the generator compartment on the firewall.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
Jim this has come up a couple of times. If I remember correctly Craig had this issue. Try doing a search. I'm on my phone or I would do it. Sorry bud I don't remember the fix but I think the ignition was bad.
