Old 10-05-2009, 07:15 PM   #1
Need help on winterizing my 39Q Berkshire
Hi all. I'm new here. I have a 39' Berkshire and wondering if someone can advise me on how to winterize it correctly ? I've gone thru the books with it and don't really see anything popping out to explain. My dealer is miles away and it's would be a costly trip just to do something simple. I've had 5 previous M/H but this one is my first Forest River and it's different. Would appreicate some advice on the steps needed. I'm sure it's straight forward but I don't want to miss something where I do damage from freezing. Thanks...Ron
Team Wilhelm is offline   Reply With Quote
Old 10-05-2009, 08:38 PM   #2
milzat's Avatar
Hi Ron,
Forest River should be no different than any other when it comes to winterizing. Plumbing is basically the same.
Click the link below.
http://searchwarp.com/swa267826.htm
milzat is offline   Reply With Quote
Old 10-14-2009, 12:40 PM   #3
Thanks Mike.
Old 11-28-2009, 08:41 AM   #4
I was able to compelte this and all is good
Old 11-28-2009, 09:09 AM   #5
kvtaylor's Avatar
Ron
I read the instructions and will add this. Be sure you run antifreeze thru your washer on both cold and hot sides, then drain it into your tank. Also if you have a ice maker, be sure there is pink antifreeze in the ice tray. I followed the repairman at our dealer when he winterized our Georgetown last year. It was done with 3 gallons of antifreeze.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 11-28-2009, 12:03 PM   #6
NWJeeper's Avatar
UMMMM, O.K. does this sound off to anyone else? The ice maker makes ice so if there was water in it after you winterize and it was to freeze what would it hurt? I absolutely would not put antifreeze in the ice tray for the absolute pain in the butt it will be to flush it out in the spring.
Ed & Wendy
www.nwjeepn.com
Old 11-28-2009, 01:20 PM   #7
TulsaSteve's Avatar
I remove fridge access panel on the outside of the motorhome and unscrew the water hose that leads into the solenoid.
- Water drains out of the solenoid so I figure I'm good that way.
- Water in the icemaker.. well heck it's an icemaker!
- I then run antifreeze until a little comes out of the hose that I unscrewed so I know that I've pushed all the water out and I screw it back onto the solenoid.
- In the spring I unhook it again and flush, then reattach it to the solenoid.
TulsaSteve is offline   Reply With Quote
Old 11-28-2009, 06:55 PM   #8
Thanks Ken and OH MY GOD we forgot the washer and dryer and ice machine THANK you a million times. Never occurred that it was to be done. This form is the best and glad I answered back. Thanks again ....Ron
Old 11-28-2009, 07:05 PM   #9
also thanks Tulsa Steve the NW Jeeper for your comments. You guys are GREAT !!
berkshire
