Old 08-11-2016, 09:00 PM   #41
Kenny kustom's Avatar
Originally Posted by Phil57 View Post
The new control has tons of features and really lets you manage your batteries to your life style.
I know!
I have the arc50, and the manual comes on a USB stick!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Bring Back The Search!
2017 Dynamax Isata 4
Old 08-11-2016, 09:09 PM   #42
62_inrightlane's Avatar
Thanks for the suggestions. With the flexibility of this controller I'll set the charge rate at 30% when I'm connected to shore power. On travel days when I use the inverter and the generator to run A/C I'll probably bump it up to 50% to make sure I maintain battery power.
Marc & Jan
Molly, Abby & Katie | The Cocker K-9 Kids!|Toad 2014 Cadillac SRX
2012 Berkshire 360FWS, Brake Buddy Vantage|Wineguard Travler SK-3005
62_inrightlane is offline   Reply With Quote
Old 08-18-2016, 07:02 PM   #43
Lowered mine down to 50%... even at a lower rate it still charges @65A!
May go even lower. Although, even at 💯 it wasn't boiling my batts.
2016 Sabre 36QBOK
Old 08-18-2016, 07:37 PM   #44
camaraderie's Avatar
If you have 4 x 6V wired in the normal series/parallel configuration ...you have about 425-460 amp hours so lets just say 400 amp hours. MAXIMUM wet cell current acceptance is roughly 25% of C (capacity at the 20 hour rate) which would be 100 amps. THAT is what you SHOULD have as your limit to most efficiently charge your batteries. They will NOT accept any more OR heat up if you use a 200 amp charger with them which is why most charging systems have NO SUCH setting limitation.
What CAN harm is high VOLTAGE at high current but you have a multistage charger so no worries there.
Bottom line... your MM1212 puts out 70 amps MAX...you cannot damage your batteries by setting the charge controller to 100% which is 30 amps less than they can safely absorb.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
charging
