Old 07-04-2015, 06:26 PM   #1
New Engine Mod
I'm thinking about doing this to my MH. Same 6.7 Cummins. MPH might take a hit but I should make good time.
FLIRTIN WITH DISASTER MAKES HUGE BOOST!! - Speed Society
Old 07-04-2015, 10:37 PM   #2
I hope you're funnin'; and I expect you are!!
You could blow your tranny in the first 50 miles.
Boowho??
boowho is offline   Reply With Quote
Old 07-05-2015, 07:16 AM   #3
For a diesel it sure got down the track. I was surprised they removed the radiator. And yes I was kidding.
Old 07-05-2015, 08:53 AM   #4
tmmar's Avatar
Phil,
Looks like you are really going to need to tighten those seat belts for that one!!
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-05-2015, 09:12 AM   #5
Islander's Avatar
The hard part of doing this Mod is....is after the light turns green regaining steering control.. when the front end comes back down in contact with the road !
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 07-05-2015, 09:25 AM   #6
accumack's Avatar
As Tim the Tool Man Taylor would say more power!
accumack is offline   Reply With Quote
Old 07-05-2015, 09:52 AM   #7
Would be sort of like that guy that goes around airshows, etc with a jet-powered semi tractor.
There are probably better videos showcasing the truck, but watch this video all the way thru. I've been a pilot for over 50 years and the guy with the Pitts special and the motorcycle.... Well let's just say he's making the plane do an "unnatural act". Simple brute horsepower is the only way I can figure on how he does it.
Also the guy jumping the motorcycle is a really talented rider. Pay close attention to his flips and rolls.
Anyhow, I've read some on the truck and it uses STOCK tires except they are "shaved" down a small amount (like less than a inch) to reduce the tires weight. Supposedly it hits 300 MPH.
boowho??
Old 07-05-2015, 11:09 AM   #8
Jim34RL's Avatar
I think you really need this engine as it will definitely pull your motor home on any incline you can find.
Scheid Diesel Prostock Pulling Engine
I believe the engine is a just little south of $38,000.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
modifications
