03-07-2018, 11:52 PM
Newby question: What is the LP Heater?
What is it and should it be on or off?
03-08-2018, 12:07 AM
LT? Do you maybe mean LP? If so, the LP heater is the furnace. Uses propane (LP) for heat and 12v power for the fan.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
03-08-2018, 12:10 AM
Where did you see this? On a switch or in the breaker panel?
03-08-2018, 07:49 AM
Typo. LP Heater. It is displayed on the Precision Panel inside the coach.
03-08-2018, 07:54 AM
Might be the Water Heater? Youroo!!
12 volt fuse. On a switch? leave it on.
03-08-2018, 07:55 AM
Typo in title corrected by site team.
03-08-2018, 08:00 AM
Agree.
Bruce
03-08-2018, 08:24 AM
fdwarren - Take a picture and post it, please. We can help you a lot better, if we can see what you see.
Without seeing it, the LP on the control panel inside is likely to select propane for the water heater. There should also be one which is labeled electric near it.
The furnace (heats using LP) is usually controlled via the thermostat.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
03-08-2018, 09:27 AM
I think the OP has a Berkshire with an electronic control panel. I may move this thread to the Berk subforum to help.
2011 Flagstaff 831 RLBSS
03-08-2018, 09:31 AM
On if you want heat.
03-08-2018, 09:54 AM
Regardless what it is or turned On/Off,when you find out the Correct answer PLEASE come back here with the Answer! Youroo!!
03-08-2018, 10:41 AM
BobbyJ
You can call Precision Circuits and speak to George, but to answer your question it is the water heater. It sends 12v current to the Truma. Turn it on first, then go outside and turn on the water heater. Then go inside and turn the dial in the bath one click counter clockwis to get a yellow light. Enjoy!
Bobbyj
03-08-2018, 10:59 AM
LP Heater is the label for turning on power for the Girard hot water heater in my 38A.
03-08-2018, 11:30 AM
Thanks Bob and Patrick. That should help the OP. Now we all know.
