Originally Posted by bcullifer
Try getting power from Generator, but that didn't work. thanks
HMMM, you stated you have a transfer switch/box and that 'should' give priority to the generator when you turned it on.
The lights going dim is usual indicative of the battery depleting and/or the converter not functioning.... since the converter is what provides power to your RV's 12 volt DC items (like the lights) when connected to shore power or generator.
An inverter takes 12 volt dc and inverts it to 120 volt AC. Don't know if your television runs off the inverter, but possibly could unless it's maybe a 12 volt DC type television. This thread link below may help explain it better:
http://www.forestriverforums.com/for...nt-152813.html
Are you getting 120 volt AC power to other things in your RV when connected to shore power or the generator? I'm asking this as it seems like at initial glance that maybe you are not getting 120 volt AC power either thru the shore power or the generator to the converter...thus things are running off the batteries and they are now depleted.
Trying to determine if it's a power connection issue, a converter issue, and/or an inverter application.
