Old 06-11-2013, 03:29 PM   #1
tmmar's Avatar
Now I know why jacks are punching through
I bent a jack pad on my coach when I was at Freightliner in Gaffney and was getting ready to level my coach. Backed into a spot and lowered the jacks and there were cement wedges that you see in the front of parking spots in malls, etc. that I didn't see. The jack came down and slid off the cement wedge and bent the pad almost in half. Looked ugly but still was ok and it didn't punch through. Contacted Equalizer for replacement pads. I received the pads and the new pads were hexagonal and mine are round. I removed the old pad and compared it to the new pad. The steel on the new pads is 1/2 the thickness of the old pad that I removed so I can see why the new one punch through. I called Equalizer and they assured me that the new pads will not punch through. I am hoping that they are right because, as I said, the steel on the new pad is 1/2 the thickness of my pads. I didn't change the second pad because I am concerned about the durability of the new pads so I will just keep it as a spare. Hopefully the new ones will hold up.
Sorry this post is so long but wanted everyone to know that Equalizer is really scrimping on their product.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-11-2013, 03:35 PM   #2
Might not be a cheaper steel just because it is thinner, might be a higher strength carbon steel which would be much stronger. Why not straighten the old one or take it to a welding shop and let them straighten it with heat?
Old 06-11-2013, 03:45 PM   #3
tmmar's Avatar
I'm not an expert but I'm pretty sure that the new one is not carbon steel. It just seems that they are punched from a sheet of thin metal. Also, my old one is over 1/4" thick and not sure it could be straightened without ruining the pad.
Tom and Margaret
Old 06-11-2013, 04:09 PM   #4
Himcules's Avatar
can you take pictures so we can see the difference? tia!
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 06-11-2013, 04:24 PM   #5
You can do a quick spark test and notice the difference in the spark given off. Just because it is 1/4" thick does not prevent it from being heated and straightened with destroying it. A little heat and a crescent wrench will do wonders for straightening steel.
Old 06-11-2013, 04:42 PM   #6
tmmar's Avatar
Hopefully this will work. Old on left, new on right.
Snapfish: Share:Registration
Tom and Margaret
Old 06-11-2013, 04:56 PM   #7
New one looks to be 3/16" thick and was sheared, not punched. Old one is definitely thicker matl and looks stronger strictly because of the gussets, but if the new one is a higher carbon steel it might be stronger.
Old 06-11-2013, 07:10 PM   #8
Himcules's Avatar
Old 06-11-2013, 09:04 PM   #9
The new one looks just like the ones they sent me.
If you think THOSE are not strong enough, you should have seen the original ones that came off my coach.
Was a single sheet of 3/16 inch steel plate, without the gusset that meets the piston.
Replacement are TWO pieces of 3/16 stock welded together PLUS the gusset. Eq Sys told me they tested the new ones to 12K lbs with no failure.
I can't tell from the picture on the right if it is a single sheet or two sheets of material.
Boowho??
boowho is offline   Reply With Quote
Old 06-12-2013, 08:11 AM   #10
tmmar's Avatar
boo,
The new one they sent me (on the right in the picture) appears to be single ply. And, as you can see, the old one from my coach is much more substantial than the new one which is why I left one of the old pads on my coach instead of changing out to the new one.
Tom
Tom and Margaret
