Old 11-06-2015, 08:13 AM   #101
silver's Avatar
Originally Posted by I-RV View Post
As for Silver's thought in tracing wires, I have seen telephone guys trace wires with a tone generator. One thing I do not have, but may be a worthwhile tool. Here is one that I found:
Multifunction RJ-45, BNC, and Speaker Wire Tone Generator | Tracer | Tester - Monoprice.com
I would think that you could pull the slide switch panel off, check for voltage (should be none) and inject the tone. Then trace the tone.
Hank
I got a tone tracer at Harbor Freight for I THINK $24. Works good. I use it for this type of thing.
silver is offline   Reply With Quote
Old 11-06-2015, 08:52 AM   #102
dan-nickie's Avatar
Originally Posted by silver View Post
I like this. This gets back to my theory of a Forest River circuit. Do you remember which fuse you pulled? Could you take a picture of it and post for kenny? I think you both have same year coaches. Maybe he can disable the circuit by pulling the fuse to gain slide access and at least close things up.
Coach is in my storage away from the house right now.
But I believe it is in the third fuse box from the left, second one down from the top.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 11-06-2015, 09:16 AM   #103
Fulltime in our Berkshire
KennyGolub's Avatar
Ken, I have been following your problem and know that you are probably grasping at straws now. Well here is a straw from just logic:
Since all of your slides stopped working at the same time, one theory would be the ignition lockout that prevents the slides from working when on. In researching the Freightliner schematics (there are no FR schematics - LOL). There is a fused 10A ignition and accessory interface to the body builder (ie: FR). You can start there; checking those fuses.
Since this line is probably only a signal line (not for power), it probably feeds a relay somewhere (only FR and God knows where) that turns on power to the slides when the ignition is off.
Just a straw of a thought.
Hank
I did pull every fuse in the outside 12v access compartment directly below the driver. Measured each for open and all were fine.
Are there more fuses under the dash ?
I am positive it's a fuse somewhere to lock out all four. I only wish I was there when it happened so I would know if there were any noises that accompanied the failure. DW is not a good source of information for things like that.
To summarize: I pulled all the fuses I could find and tested them. This included the 12v fuse panel on the outside by the driver, whatever fuses I could find by the batteries (both house and chassis) and an inline fuse right at the motor.
Additionally, there is a clearly marked relay (tape with the word "Slides" on it) in the 12v compartment. I ordered a replacement and tried it with no change. There are several relays there and all are marked nicely.
My last hope prior to taking it in (or having a tech come out) is a response from Randy with any more ideas he may have.
Silver:
Good luck with the surgery. Hope it works out well for you.
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 11-06-2015, 09:24 AM   #104
dan-nickie's Avatar
Kenny, does your awning work?
It is tied into the ignition lockout mentioned above.
Dan
Old 11-06-2015, 09:34 AM   #105
silver's Avatar
Hi Kenny,
I bet the slides relay provides 12 volts back to the slide control panel and is a normally closed relay. Do you have the pin out for the relay. Was it at the web site where you ordered it? I would remove the relay and measure the contact legs to first see if power is on one. Then measure each side of the coil. One side will be at ground and the other open with ignition off. With ignition on the other should be 12V, This might help isolate your problem. If you give me the relay part number I will look up the spec to be sure of my guess and tell you exactly how to make the measurements. This has to be something silly if we can just find it.
Old 11-06-2015, 12:58 PM   #106
KennyGolub's Avatar
Hi Kenny,
I do not have the part number here at work, but I will post it once i get home this evening.
Thanks !!
Ken & Laurie
2016 Chevy Colorado
Old 11-06-2015, 12:59 PM   #107
KennyGolub's Avatar
I will try the awning when I return home.
Thanks !!
Ken & Laurie
2016 Chevy Colorado
Old 11-06-2015, 03:52 PM   #108
gasman94's Avatar
Man Kenny, sorry for your troubles! Hopefully this experience will help someone else in the future, once you get it resolved.
Rich
gasman94 is offline   Reply With Quote
Old 11-06-2015, 04:46 PM   #109
KennyGolub's Avatar
Thanks Rich.
I tried the awnings and they both work.
Silver:
Part number of the relay is :
V2323A-A1001-X036
Ken
Ken & Laurie
2016 Chevy Colorado
Old 11-06-2015, 04:51 PM   #110
gasman94's Avatar
Ok. I'm feeling bad so I got out to the storage place and take a pic of hydraulics bay. There is an inline fuse there. Did you check this (sorry if previously posted).
Rich
ID:	93819   Click image for larger version
slide, slide out
