Old 11-09-2015, 08:05 PM   #121
I-RV's Avatar
Originally Posted by KennyGolub View Post
Where are those two fuses located?
Not sure. I did see on the schematic that one of them went to a body builder connector. I'll look for them in the daylight tomorrow
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-09-2015, 08:25 PM   #122
I-RV's Avatar
Kenny, I found the schematic that I was looking for. Check it out.
Hank
Old 11-10-2015, 06:15 AM   #123
Fulltime in our Berkshire
KennyGolub's Avatar
Hank
Thanks !!!
I am going to call and get approved, a service tech to come out and fix it. It will probably be a while before they come out as in three weeks, they are gearing up for the RV show in January.
So, I still have time to take more measurements and search for more fuses. Most of my testing will be done on Saturday's, so I probably will not get to post any results until then.
Thanks again for going through the trouble of digging that out !
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 11-11-2015, 02:22 PM   #124
Kenny, I just sent you a PM. Randy has always responded faster to phone calls. Good luck.
Paul
Paulie Boy is offline   Reply With Quote
Old 11-11-2015, 02:28 PM   #125
gasman94's Avatar
[QUOTE=Paulie Boy;1033032]Kenny, I just sent you a PM. Randy has always responded faster to phone calls. Good luck.
I did as well. Same thought process. Great minds
Rich
gasman94 is offline   Reply With Quote
Old 11-11-2015, 02:41 PM   #126
KennyGolub's Avatar
And I toast the two great minds
Thank you !
Ken & Laurie
2016 Chevy Colorado
Old 11-11-2015, 04:10 PM   #127
silver's Avatar
Measure that relay socket and tell me what you get. Then we can narrow down where the problem is. Again with the key on and off.
silver is offline   Reply With Quote
Old 11-11-2015, 05:45 PM   #128
KennyGolub's Avatar
Silver
Will do. I can't get to it until Saturday
Ken & Laurie
2016 Chevy Colorado
Old 11-13-2015, 08:02 PM   #129
silver's Avatar
Silver
Hi Kenny,
When you measure the relay socket if you get no voltage at ether pins 87, 87A and pin 30 short pin 87A to pin 30 using a paper clip then connect the center of the paper clip to +12v. If that is the slide control relay and I am right your slides should work. You might want to have a fuse between the paperclip and the +12v line you choose. Be careful. You cannot get hurt But need to be careful for coach. That is reason to use fuse, Maybe 20 amp. That is what I would do at this point. May want wife to run slides so you can watch fuse. Let me know what happens. Run one slide at a time. I would just close up.
Otherwise let me know what you measure with with key on and key off at each point of the relay socket. There is a ground bar at the top of the electrical bay you can use for one side of the meter. Have meter set to dc volt scale.
I go in for surgery Monday and will be off line after that.
Name:	slide relay 2.jpg
Old 11-13-2015, 09:48 PM   #130
gasman94's Avatar
Silver, hope nothing major with your surgery. Good luck.
Kenny, hope things are getting better there.
Rich
slide, slide out
