Old 10-31-2015, 11:09 AM   #11
Fulltime in our Berkshire
KennyGolub's Avatar
All good things in the suggestions but I have checked all loans and cannot find any problem I was an error about the heat pump though because it does turn on now but the fireplace still will not turn on and of course the slides will still not work I did not see anything I can reset in the battery compartment but I did check that big high voltage shoes there and that does check ok a my multimeter
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 10-31-2015, 11:10 AM   #12
KennyGolub's Avatar
Don't you just love spell check sorry for the misspellings but I'm using the microphone on a cell phone and it doesn't always put down what I'm trying to say
Ken & Laurie
2016 Chevy Colorado
Old 10-31-2015, 11:26 AM   #13
Berkshire 390QS
NO3putt's Avatar
Ken,
On ours anyway, for the inverter, there is a AC breaker under the bed for the inverter and also a on/off and small push button breaker on the inverter itself. have had our breaker on the inverter trip a few times.
if you have a night light, just take it and check each outlet in the coach and see if any of you outlets are not working, then like tmmar said could be a GFI outlet popped. on ours there are you outlets that are GFI protected, one in kitchen and one in bath.
Skip
Old 10-31-2015, 11:26 AM   #14
You might try unplugging from land power and turn on inverter to see if fridge and micro work ok, slides should also work. That will test some of the 12 volt circuit.
Then try generator by itself and see what works.
Good luck.
Bill
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 10-31-2015, 11:36 AM   #15
Are the slides hydraulic or electric?
yelrow917 is offline   Reply With Quote
Old 10-31-2015, 11:38 AM   #16
Does the Emergency Brake have to be applied? Might look there. Just a thought.
dphorton is offline   Reply With Quote
Old 10-31-2015, 11:41 AM   #17
Also are the slides on separate swithes or are they all on one switch?
Old 10-31-2015, 11:50 AM   #18
Campin Cajun's Avatar
Kenny, try deploying the jacks. They run off the same hydraulic pump.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-31-2015, 11:54 AM   #19
I know this isn't it but is the key in the ignition? That will not allow them to work.
Old 10-31-2015, 12:29 PM   #20
Do you have a battery switch shutoff?? Maybe it got turned off by mistake.
chuckteri is offline   Reply With Quote
slide, slide out
