Old 10-31-2015, 10:47 PM   #41
2014 Berkshire 360QL
It is true that the fire place with not operate with the slide in.
Richard D is offline   Reply With Quote
Old 11-01-2015, 06:28 AM   #42
Fulltime in our Berkshire
KennyGolub's Avatar
Mine actually does. I do it all the time in the winter when I am exercising the generator.
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 11-01-2015, 07:12 AM   #43
dan-nickie's Avatar
In our 2014 RB there are 2 A/C plugs side by side in the A/V cabinet above the fireplace.
One turns off with the slide and the other doesn't.
I found that out when I re-arranged the audio/video equipment and my TV wouldn't come on with the slide in.
I had swapped plugs and didn't realize it.
Wonder if your plugs are swapped also?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 11-01-2015, 07:37 AM   #44
KennyGolub's Avatar
I do think that the DW unplugged the fireplace and will confirm that shortly.
As for the slides, I am going to start pulling every 12v fuse and check them even though none are labeled for the slides.
Ken & Laurie
2016 Chevy Colorado
Old 11-01-2015, 07:48 AM   #45
I know the ignition is wired to prevent the slide moving when the key is in. Could something be shorting in that. I imagine it a ground that prevents the slide working. I'm not sure where that would be.
Old 11-01-2015, 08:21 AM   #46
slides not working
there is a fuse 15 amp inside control box by batteries that controls slides on my Georgetown
spidergolf1 is offline   Reply With Quote
Old 11-01-2015, 09:43 AM   #47
KennyGolub's Avatar
Well I just got finished pulling every single 12 volt fuse I could find in the coach.
I tripped across one that was bad but that was for the dash radio and after replacing it obviously did nothing.
I found the two in the battery compartment they checked okay also.
Last resort now I'm trying the reboot method someone mentioned previously and if that don't work and I guess it's time for a tech
Ken & Laurie
2016 Chevy Colorado
Old 11-01-2015, 09:49 AM   #48
Ken has it been determined that the motor is operable ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 11-01-2015, 10:02 AM   #49
When I first got my coach, on the first night out, we put the slides out, and next morning none of them would go in. Like everyone, I checked all fuses and breakers, but nothing worked, I then just kept pushing the slide buttons on and off, and low and behold, they started to work and all came in. I went directly back to the dealer to have it checked. The repair technician discovered that there was a relay that controls the slides, and it would work intermittently. Sometimes it worked fine, then it wouldn't. He replaced the relay, and all has been fine since. That could be your problem, It is worth checking.
2012 Berkshire 360-FWS
2003 Jeep Liberty Dinghy
Roadmaster All-Terrain
BrakeBuddy
hawk10eye is offline   Reply With Quote
Old 11-01-2015, 10:08 AM   #50
KennyGolub's Avatar
Yes I did find that really it's fairly well marked in the 12 volt fuse compartment next to the driver.
I think I'll replace the relay next.
I found that the hydraulic motor works by using the jacks and it runs fine
Ken & Laurie
2016 Chevy Colorado
slide, slide out
