Old 11-01-2015, 10:18 AM   #51
tmmar's Avatar
Damn Kenny- you really come up with some good ones for us here on the Forums! Hope someone comes up with a solution or something you replace fixes the problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-01-2015, 10:34 AM   #52
accumack's Avatar
Originally Posted by Phil57 View Post
I know the ignition is wired to prevent the slide moving when the key is in. Could something be shorting in that. I imagine it a ground that prevents the slide working. I'm not sure where that would be.
My slides work with the key in but not on. I leave the keys in the ignition all the time. I wonder if mine is wrong.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-01-2015, 10:37 AM   #53
So many differences from year to year. Even many within a model year. I don't think you have a problem. If the slide didn't start to go out a little I would look mare at the ignition. Being that it went out and quit it seems like a fuse.
Old 11-01-2015, 12:40 PM   #54
Slides not working
My fuse is in the box above the battery I had two take the cover off to get to it
spidergolf1 is offline   Reply With Quote
Old 11-01-2015, 01:03 PM   #55
Fulltime in our Berkshire
KennyGolub's Avatar
No boxes in the battery compartment, besides the one big fuse with a plastic cover
Going to order a new relay and try that.
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 11-01-2015, 01:55 PM   #56
accumack's Avatar
Did you reset the the breaker on the top of the inverter?
Ham KG5LTL.
Old 11-01-2015, 01:57 PM   #57
KennyGolub's Avatar
I couldn't find any type of breaker inside the converter compartment other than the little 30 amp Pop out fuse which was fine
Ken & Laurie
2016 Chevy Colorado
Old 11-01-2015, 02:20 PM   #58
accumack's Avatar
It is a tiny switch on top of our inverter. I couldn't see it but felt it. Our outlets next to the bed didn't work. I have a CPAP machine and we were boondocking and the outlets were dead.
Ham KG5LTL.
Old 11-01-2015, 03:32 PM   #59
fuse for slides
Mine is under the stair in the battery box area and it is a black box with control center label, remove the cover you should see fuses,I had same problem and found a 15 amp blowen
Old 11-01-2015, 03:39 PM   #60
tmmar's Avatar
spider,
Don't know what type of camper you have (sounds like you have a class C), but there is no battery box in our coaches that are under steps. This is a Berkshire class A on a Freightliner chassis.
Tom and Margaret
slide, slide out
