Old 11-18-2015, 07:35 PM   #161
accumack's Avatar
Have you pulled the switch panel and checked to make the switch hasn't gone bad or that you power to that point?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-18-2015, 07:36 PM   #162
gasman94's Avatar
Originally Posted by I-RV View Post
Maybe that a wire tone tracer will now work. You can inject the tone at the relay where the 12 volts is supposed to be and trace it to its source.
Don't have one, but have seen telephone guys used them in my home. I hear that Harbor Freight has them.
Hank
Looked at HF and didn't see one. Amazon carries a bunch of different ones and they aren't too expensive. Nice to have in the arsenal, also.
Rich
gasman94 is offline   Reply With Quote
Old 11-18-2015, 07:57 PM   #163
gasman94's Avatar
Looks like Silver gets the crown this week. Good job
Rich
Old 11-19-2015, 05:04 AM   #164
KennyGolub's Avatar
I have pulled the panel to make sure all connections were good and nothing else obvious might be wrong there, but have not measured anything there yet.
I will do that Saturday.
Thanks !
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is offline   Reply With Quote
Old 11-19-2015, 05:06 AM   #165
KennyGolub's Avatar
Hank
I have seen them at the local Home Depot. One may be in my future.
Thanks,
Ken
Ken & Laurie
Old 11-20-2015, 09:21 PM   #166
silver's Avatar
Originally Posted by KennyGolub View Post
Thanks to Silver, I was able to put a jumper to the relay and get the slides to close.
Now I just have to find out why 12volts are not getting to the relay.
Thanks Silver!!! I hope your surgery went well.
Ken
Hi Kenny,
Glad it worked. now you have a few decisions. You checked all the fuses and found none bad. Let's assume that is true, This leaves us with the connection at relay socket 87A broken. I suspect a bad splice. Others have had this happen elsewhere in the coach. To find you need to strip back the cable harness leading to the fuse holder and re-crimp. Could be a foot or many feet away, You could forget about finding the break in the wire and take the jumper you made and connect to fuse holder 87A. Repair complete and coach works as before, You could just leave the jumper connected to point 30 and have Forest River repair at the next frog rally. If you go the Forest River Repair route be aware the slides will now work while the coach is running down the street.
silver is offline   Reply With Quote
Old 11-20-2015, 09:25 PM   #167
Silvers back. Good to hear from you. Hope all went well.
Old 11-20-2015, 09:30 PM   #168
gasman94's Avatar
X2. Hi ho Silver
Rich
Old 11-20-2015, 09:38 PM   #169
silver's Avatar
feels like I got run over by a truck or maybe a motorhome. With all the nonsense regarding painkillers in the news recently I was prescribed 1000mg Tylenol every 6 hours for pain (knee replacement). All that did was eat a hole in my stomach. But yes I am back. Not quite as quick yet so be kind.
Old 11-20-2015, 10:01 PM   #170
gasman94's Avatar
Silver, sent you a pm.
Rich
Old 11-20-2015, 10:12 PM   #171
That doesn't sound good. You don't need stomach problems on top.
Old 11-21-2015, 06:24 AM   #172
silver's Avatar
You guys gave me an idea for my avatar. Of course the wife thinks it should be a jackass.
Old 11-21-2015, 06:43 AM   #173
KennyGolub's Avatar
Silver:
Thanks again for all the good info.
Happy to see you are back from the surgery. Here's hoping for a quick recovery.
Ken
Ken & Laurie
Old 11-21-2015, 06:43 AM   #174
silver's Avatar
Try the avatar again
Old 11-21-2015, 07:56 AM   #175
I-RV's Avatar
Hi-Ho-Silver rides again. Glad that you are on the mend, This must be you.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-21-2015, 09:54 AM   #176
tmmar's Avatar
Originally Posted by gasman94 View Post
X2. Hi ho Silver
Rich
Damn Rich, was just going to post this!! You beat me to it!!
Silver, hope you have quick recovery and are back on the road real soon!
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-21-2015, 10:02 AM   #177
tmmar's Avatar
Great, that means the even though I need a cane to get around due to my bad back, you will be easy to catch!!
Tom and Margaret
Old 11-21-2015, 12:48 PM   #178
gasman94's Avatar
Hey Tom, just ordered this. I'll let you know what it's like.
http://www.amazon.com/gp/product/B00...ilpage_o00_s00
Rich
Old 11-21-2015, 01:08 PM   #179
tmmar's Avatar
Rich,
Looks great! Let me know how you like it! Don't know about the neck pillow part though. Might make it a bit too comfy when driving and cause me to nod off every once in a while!!
Tom and Margaret
Old 11-21-2015, 03:01 PM   #180
silver's Avatar
This has a disturbing sound to it
slide, slide out
