Old 10-31-2015, 09:43 AM   #1
KennyGolub's Avatar
Oh Crap .... Slides don't work
The DW finally informs me today that she was trying to open the slides yesterday and they stopped after a couple inches.
There is no power for any of the four slides.
Power everywhere else seems okay.
I've checked the fuses under the bed and all look fine.
Is there any hidden fuses I don't know about for the slides ?
Thanks,
Ken
Ken & Laurie
Retired Cleveland CPD
2019 Entegra Aspire 44W
2018 Jeep Wrangler Unlimited
KennyGolub is offline   Reply With Quote
Old 10-31-2015, 10:20 AM   #2
accumack's Avatar
Are you hooked up to power? the batteries maybe low?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 10-31-2015, 10:24 AM   #3
tmmar's Avatar
Kenny,
How about the fuses in the outside compartment on front drivers side of the coach? Many 12v fuses there.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-31-2015, 10:24 AM   #4
KennyGolub's Avatar
Thanks for the reply but yes hooked up the power 24/7
Ken & Laurie
Old 10-31-2015, 10:33 AM   #5
KennyGolub's Avatar
yeah I looked they were all labeled on the 12 Volt by the driver side door and I and I could not see anything 4 slides or pump I did find an inline fuse right by the hydraulics but that checked okay its a 20 amp fuse
Ken & Laurie
Old 10-31-2015, 10:37 AM   #6
tmmar's Avatar
I think that there is a fuse in the house battery compartment that is between the cables for batteries. That might have blown.
Tom and Margaret
Old 10-31-2015, 10:56 AM   #7
KennyGolub's Avatar
I did check that large fuse in the battery for the house compartment and that is OK I found something new though the electric fireplace and the front air conditioner for the heat pump will not turn on either so there's got to be a good size to somewhere that stopping those things from working
Ken & Laurie
Old 10-31-2015, 10:58 AM   #8
fonzie's Avatar
If wired similar to Georgetowns, you might have a breaker ( close to 100 amps) in or near the battery compartment that needs to be reset....
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 10-31-2015, 11:03 AM   #9
Berkshire 390QS
NO3putt's Avatar
Ken,
the air conditioner, fire place and heat pump will be AC current (120 volt) and the slides I believe run on 12 volt battery. Things to check for AC, Fire Place and heat pump would be your AC breakers, ours are under bed. is any of your AC things working? Microwave as an example?
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 10-31-2015, 11:06 AM   #10
tmmar's Avatar
Ken,
How about a GFI outlet? Could one of those have tripped?
Tom and Margaret
Old 10-31-2015, 11:09 AM   #11
KennyGolub's Avatar
All good things in the suggestions but I have checked all loans and cannot find any problem I was an error about the heat pump though because it does turn on now but the fireplace still will not turn on and of course the slides will still not work I did not see anything I can reset in the battery compartment but I did check that big high voltage shoes there and that does check ok a my multimeter
Ken & Laurie
Old 10-31-2015, 11:10 AM   #12
KennyGolub's Avatar
Don't you just love spell check sorry for the misspellings but I'm using the microphone on a cell phone and it doesn't always put down what I'm trying to say
Ken & Laurie
Old 10-31-2015, 11:26 AM   #13
Berkshire 390QS
NO3putt's Avatar
Ken,
On ours anyway, for the inverter, there is a AC breaker under the bed for the inverter and also a on/off and small push button breaker on the inverter itself. have had our breaker on the inverter trip a few times.
if you have a night light, just take it and check each outlet in the coach and see if any of you outlets are not working, then like tmmar said could be a GFI outlet popped. on ours there are you outlets that are GFI protected, one in kitchen and one in bath.
Skip
Old 10-31-2015, 11:26 AM   #14
You might try unplugging from land power and turn on inverter to see if fridge and micro work ok, slides should also work. That will test some of the 12 volt circuit.
Then try generator by itself and see what works.
Good luck.
Bill
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 10-31-2015, 11:36 AM   #15
Are the slides hydraulic or electric?
yelrow917 is offline   Reply With Quote
Old 10-31-2015, 11:38 AM   #16
Does the Emergency Brake have to be applied? Might look there. Just a thought.
dphorton is offline   Reply With Quote
Old 10-31-2015, 11:41 AM   #17
Also are the slides on separate swithes or are they all on one switch?
Old 10-31-2015, 11:50 AM   #18
Campin Cajun's Avatar
Kenny, try deploying the jacks. They run off the same hydraulic pump.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-31-2015, 11:54 AM   #19
I know this isn't it but is the key in the ignition? That will not allow them to work.
Old 10-31-2015, 12:29 PM   #20
Do you have a battery switch shutoff?? Maybe it got turned off by mistake.
chuckteri is offline   Reply With Quote
slide, slide out
