Old 08-02-2014, 10:53 PM   #11
gasman94's Avatar
Originally Posted by Crusadernoob View Post
Just change the filter also, don't half ass it! You got 10 months on it, almost time per cummins anyway.
I know, I know, but I just keep thinking that I'll be changing the oil again in about a month and a half. I'm usually the guy that goes that extra little bit also.
Rich
gasman94 is offline   Reply With Quote
Old 08-03-2014, 06:59 AM   #12
Rich I would run it and do the oil change and filter when you get home. Just check it at stops after a long run.
Old 08-03-2014, 07:09 AM   #13
I agree with Phil, change it and filter when you get back, you'll be fine. If it makes you sleep better change it now but don't skimp $15, change the filter at the same time. It literally takes 5 minutes.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 08-03-2014, 03:43 PM   #14
gasman94's Avatar
OK. So I changed both the filter and the oil. Learned a couple of things. (1) None of my filter wrenches would work, so I had to go buy a strap wrench that used a 1/2" ratchet. (2) Took 18 qts. (I thought it was 16). (3) I now know where the fuel filter is (that's another story). The oil was not really that bad, after all. Felt quite slippery and no grit. I've been wrenching on cars for over 45 years and am reminded about how much I don't know about diesels.....but I like learning.
Also a quick question. To drain the water separator bowl, do you turn the plastic valve at the bottom of the bowl right or left to open? I'm assuming clockwise, but it did not seem to want to go either way and I didn't want to break it. It also has a wire connection, so I'm assuming it is for some type of indicator????
Thanks for all the advice.
Rich
Old 08-03-2014, 03:56 PM   #15
RSchleder's Avatar
To open it you should turn it clockwise when looking down from the top of the filter. I always started my engine and drained it very slowly so you don't de-prime the fuel system. You really don't want to do this----Ask me how I know!!!!!!! As they say, live and learn, which was easy to do after my first time of sitting on the engine ( bed up) and reading the owners manual on how to prime the engine by sequentially opening and close valves in the fuel line while my wife turned the engine over with the starter.
Yes, the wire is a connection to the sensor that gives a signal on the dash if the system has water in it and needs to be drained.
RSchleder is offline   Reply With Quote
Old 08-03-2014, 04:27 PM   #16
If I was going to change just one thing it would always be the filter. Oil gets dirty but does not wear out. Worked in the natural gas industry and we ran our oil for years but changed the filters regular basis. I know different kind of engine but the same basic principals.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 08-03-2014, 04:31 PM   #17
gasman94's Avatar
So if I'm laying on my back looking up, I should turn counterclockwise? Should it turn easily? Also, appreciate the sharing of your personal experiences. Thanks.
Rich
Old 08-03-2014, 10:24 PM   #18
NV245's Avatar
Make sure of fuel bleeding procedures, the Cummins uses a "common rail" injector system that does not require the bleeding of air to injectors, and at the fuel pressures used, fuel can be injected into the person attempting the procedure. Flesh and Diesel fuel do not mix!
NV245 is offline   Reply With Quote
