Old 09-23-2015, 07:57 PM   #11
silver's Avatar
Trans fluid is good for 300000 miles. All you need to do is change the filter. For those with the 2500 transmission it is filter Allison 29539579 or Fram P9264. Will only loose what is in the filter. Just replace the filter amount when done.
The 3000 transmission has two filters but I do not know their numbers.
It is the radiator fluid that is good for five years. Of course if you get a new radiator like I am the fluid gets changed automatically. Sort of a tough way to go however.
silver is offline   Reply With Quote
Old 09-23-2015, 08:31 PM   #12
Thanks Silver. I new something was 5 years.
Old 09-23-2015, 08:44 PM   #13
Motodad's Avatar
Originally Posted by chesterhull View Post
Finally got to this today. 16 qts of oil, a new filter, and got the old oil dumped. No issues, other than *almost* starting to unscrew the main fuel filter instead of the oil filter! (Hey, it was first time to change the oil...don't laugh!)
All in all, not bad...$11 for the filter and $48 for the oil...plus I didn't have to drive it somewhere to have it done.
Though it's nice to know about what it would have cost me. I'm thinking to have the trans fluid and filter changed by someone else, but we'll see!
It's 17.6 quarts in mine. 340hp
Motodad is offline   Reply With Quote
Old 09-23-2015, 09:31 PM   #14
jmgllt's Avatar
Lots of good info!
jmgllt is offline   Reply With Quote
Old 09-24-2015, 08:02 AM   #15
Name:	ImageUploadedByForest River Forums1443099550.382685.jpg
I just had the full service on the chassis, engine plus filters and generator plus filters and full chassis lube just the other day. The mechanic (owner) left this card with me. These are the updated intervals recommended by the manufacturers
Paul
Paulie Boy is offline   Reply With Quote
Old 09-24-2015, 08:24 AM   #16
Originally Posted by Paulie Boy View Post
Attachment 89717
Paul
That's a slick card, Paulie Boy!
My Berk is a 2008. I'm the second owner, and bought it with 10k miles on it. It's 19.5k now, so I'm late on the 15k oil change! :-)
According to the years I need to do a trans fluid/filter change, but I may wait until 25k. I always have a tough time changing fluids on the time interval when the mileage is so low!
Speaking of chassis lube...does anyone have a sheet of lube points?
chesterhull is offline   Reply With Quote
Old 09-24-2015, 09:57 AM   #17
The tranny lube depends on the Dexron III in the older models and the TranSynd in the later models. I'm not sure when they started using the TranSynd but I was told my 2014 had it.
Paul
Old 09-24-2015, 10:11 AM   #18
tmmar's Avatar
They started using the TranSynd in '08. I know this because my '08 had TranSynd in the transmission.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 09-24-2015, 10:20 AM   #19
I have read that FL ships the chassis with no Trans fluids in it. The fluid is drained after assembly and test and shipped dry. The manufacturer in this case FR fills them at delivery. I don't think it makes sense and I wonder if anyone knows if this is true.
Old 09-28-2015, 08:41 AM   #20
I-RV's Avatar
I get a feeling from this thread and others that many do not follow the Freightliner and Allison services schedules either knowingly or unknowingly. I agree that it is every owners individual decision concerning service, but I'd like to point out that while the large items like the engine and tranny are under warranty, should anything go wrong, the owners service records may be inspected.
As for this thread, the Allison 2500MH (which I have) should have its fluid changed (having Transynd TES-295) every 300,000 mi or 48 mo. Note that Mobil Delvac fluid can be used. The filter should be changes every 24 months if Prognostics are not turned on. Although my rig is a 2012, I called Allison with the tranny serial and I do not have Prognostics.
As for the Freightliner chassis and Cummins, service schedules have been supplied. I am attaching a 48 month schedule as an example. I have found that most truck service shops and even Freightliner dealers do not follow the Freightliner schedules, however Freightliner Oasis Service Centers do. I was given a service price from one local Freightliner service and then when I presented the service sheet; was given a much higher price - LOL
I feel that service decisions is each owners prerogative, but I suggest it should be a well informed decision with all the facts. - Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
