Old 08-02-2015, 11:24 AM   #1
DJP6371's Avatar
Oil filled hubs
The oil filled hubs on the front wheels of my Berk, have a "minimum" fill level, which is half way up the hub.
How "full" can they be?
Sent from my iPhone 'cause I'm probably out in the RV!
DJP6371 is offline   Reply With Quote
Old 08-02-2015, 11:49 AM   #2
Campin Cajun's Avatar
I would think all the way to the top since there is no full mark.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-03-2015, 07:35 AM   #3
jmgllt's Avatar
What is this never head of these?
jmgllt is offline   Reply With Quote
Old 08-03-2015, 07:54 AM   #4
Caution,dont fill to the Top! It is easier to see if (Partial fill in the Glass)! Youroo!!
Old 08-03-2015, 11:54 AM   #5
And not having room for expansion could blow the seals out.
Boowho??
boowho is offline   Reply With Quote
Old 08-03-2015, 11:58 AM   #6
Berkshire 390QS
NO3putt's Avatar
Couple of questions.
1. How often should one check them
2. what kind of oil and how to fill
Old 08-03-2015, 12:07 PM   #7
TURBS's Avatar
1) before every trip
2) 80w90 or equivalent
3) little plug in middle of cap or if not available there's a plug on the side of the cap, plug should be close to the top to fill.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-03-2015, 12:14 PM   #8
My Chassis mechanic said to NOT replace with synthetic if there was not already Synthetic in there. You'll need to ask FRCC what they used at the factory, but likely is was synthetic
My guy says that synthetic and regular oil do not work and play well together in the wheel hubs.
Boowho??
Old 08-03-2015, 12:16 PM   #9
Q for you do your (Hub Caps) cover the view? Youroo!!
Old 08-04-2015, 10:50 AM   #10
Yes. You have to remove the hubcaps to check/change the oil. This is one of the MAJOR (read don't ignore) maintenance items as specified by FL.
Boowho??
led
