Old 10-17-2014, 03:40 PM   #1
gasman94's Avatar
Oil Level
Just changed the oil in my Berk. Last time it took 18 qts. with the filter. I put in 18 plus the quart in the new filter. I checked the dipstick and was over full. Drained out about a qt. and am still probably about a quart heavy. I know that overfilling in a 5 or 6 quart gas motor can cause cavitation and pressure leaks, but how about a diesel with 18 qts? I will dump more if I have to, but would prefer not to. Any opinions???
gasman94 is offline   Reply With Quote
Old 10-17-2014, 04:07 PM   #2
tmmar's Avatar
Gasman,
How much over full was the level? Also, which engine do you have- the 340 or 360 hp? I believe that the 340 hp takes less oil than the 360. If it shows that it is a lot over full, I would drain more oil so that it is just at the full mark. As you mentioned, too much oil can be as bad as too little oil. JMHO
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-17-2014, 06:40 PM   #3
gasman94's Avatar
Originally Posted by tmmar View Post
Gasman,
Tom
Tom, looking at where the current mark is and comparing it with the low oil mark, I would estimate about a quart over. I had it changed at the dealership once, and they used 20 qts.....really overfilled. Someone once told me that in a diesel, the excess is just burned off, but I don't know if that is true. I dumped a bunch of that oil to get the level down.
Old 10-17-2014, 07:15 PM   #4
silver's Avatar
If you check your manual the Cummings engines pan has a 15 qt capacity. Pan, oil filter and system have a 17.6 qt capacity.
silver is offline   Reply With Quote
Old 10-17-2014, 07:27 PM   #5
gasman94's Avatar
Silver, that's what I figured from my last oil change....but, not thinking about the added amount of oil by prefilling the filter, using 18 qts. put me over. Tom, btw I have the 360..
Rich
Old 10-18-2014, 07:56 AM   #6
2011 Berkshire 390BH
Superchief's Avatar
I believe the only difference between a 340 and a 360 engine, is the chip. If that is true, the oil capacity would be the same, one would think. The main difference with 360, is a bigger transmission (3000 vs 2500).
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 10-20-2014, 06:35 AM   #7
KennyGolub's Avatar
Now that you got me thinking of oil changes......
Just curious. With my cars, I drive it up a ramp, and place an oil drop pan under the drain hole and drop the oil.
How do you do it with the Berky ? What do you use that holds 16 ~18 quarts ?
KennyGolub is offline   Reply With Quote
Old 10-20-2014, 06:56 AM   #8
rsscully's Avatar
Used this with my truck. Don't know where you would put the other 1-3 quarts.
http://m.autozone.com/autozone-mobil...N-25yj?id=2278
rsscully is offline   Reply With Quote
Old 10-20-2014, 03:53 PM   #9
tmmar's Avatar
I put a Fumoto oil drain valve in my coach. It replaces the drain plug and has a little handle that you can turn to allow the oil to drain and then turn it to stop the oil. I then can drain as much or as little oil that I want. I usually drain the oil into a large detergent jug and it takes about 2 1/2 times to drain the oil.
Fumoto Valve | Qwik Valve™
Tom and Margaret
Old 10-20-2014, 04:53 PM   #10
gasman94's Avatar
Don't need a ramp. I use a creeper from harbor freight. Also bought a 20 qt oil pan to get the oil. I'm on vacation right now, but will post the one I got when I get back.
Rich
