Old 01-06-2019, 04:24 PM   #1
Dijoeboss's Avatar
Onan Generator maintenance / engineers!
Ok, so today we got a break in the weather and I decided to go out and service my Onan RV QD 8000 Diesel generator, I was going to change the oil and filter, only changed the oil for the moment, someone thought it was a good idea to mount a bracket over the cover that you have to remove to gain access to the fuel and oil filters! this bracket has a roller mounted to it, BUT ITS RIVETED TO THE FRAME UNDER THE GENERATOR! Am I missing something???
Also, the frame under the generator covers the COOLANT DRAIN CAP! Smdh........
Still not sure how Iím going to go about gaining access to the oil and fuel filter just yet......Click image for larger version
ID:	194093Click image for larger version
ID:	194094Click image for larger version
Dijoeboss is offline   Reply With Quote
Old 01-06-2019, 04:36 PM   #2
dan-nickie's Avatar
Looks like it has bolts in addition to the two pop rivets?
Assuming that bracket is not holding up your generator, I would cut the Two pop rivets.
I'm not sure what you mean by it has a roller mounted to it.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-06-2019, 04:37 PM   #3
Dijoeboss's Avatar
The nut is a roller attached to the other side
Old 01-06-2019, 04:42 PM   #4
dan-nickie's Avatar
Maybe use a star wrench To completely remove the cover then.
Dan
Old 01-06-2019, 04:44 PM   #5
dan-nickie's Avatar
Oh, you mean the roller that the generators slides out on?
Dan
Old 01-06-2019, 08:30 PM   #6
Dijoeboss's Avatar
And the cover for the filters is partially blocked by the side of the framing- Iím calling Forest River tomorrow.... grrrrr
Old 01-06-2019, 08:33 PM   #7
dan-nickie's Avatar
Open or close the generator door enough either way to clear that bracket.
Dan
Old 01-07-2019, 01:10 AM   #8
Dragonship Captain
Oscarvan's Avatar
^^^^^^ What he said. Slide the generator so the door clears. Squeeze the two buttons, the other side lifts out. Once you figure it out it takes less than 5 seconds.
There's also a spark arrester to clear out.
There's a bunch of REALLY good Youtube videos on servicing these units.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 01-07-2019, 02:38 AM   #9
Dijoeboss's Avatar
If itís thatís easy, Iím gonna feel really stupid !!!
Old 01-07-2019, 02:40 AM   #10
Dijoeboss's Avatar
This door is still partially blocked on one side / and the coolant drain??Click image for larger version
ID:	194127Click image for larger version
generator, maintenance
