Old 11-09-2014, 05:02 PM   #1
cadbid04's Avatar
One more winterize question
I have read the threads and haven't come across an answer for this question. I have a 2014 390-60 with a residential whirlpool refrigerator. It has a water filter in the refrigerator. I ran 2 gallons of liquid out the front of the fridge and it kept coming out clear due to the water filter i would guess? I took the filter out and there was pink stuff in the filter. It won't work without filter in it. Can I assume that since pink was coming out of every other faucet that after 2 gallons even if it didn't turn pink I would be winterized? Did anyone else have this trouble?? Thanks for your advice. Chris
Chris & Brandy
2014 Berkshire 390BH
cadbid04 is offline   Reply With Quote
Old 11-09-2014, 05:16 PM   #2
tmmar's Avatar
Chris,
You should have removed the filter. There should have been a blue cap that you install after you removed the filter. I would remove the filter, because it is probably shot now anyway, put the cap in and run the pump for a minute or so to make sure you get the pink stuff coming out of the water tap on the fridge.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-09-2014, 09:01 PM   #3
cadbid04's Avatar
thanks Tom
thanks Tom- Now I know what that blue thing was I just threw in a drawer. I took the filter off and had pink coming out. Good to know the filter works on pink. Chris
Chris & Brandy
Old 11-10-2014, 10:50 AM   #4
Gottawonder's Avatar
Time to go look for a blue cap... anyone happen to shoot a pic of this?
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
Old 11-10-2014, 01:19 PM   #5
tmmar's Avatar
This is a picture of the cap installed. Remove the filter and put the cap in in place of the filter inside the refrigerator.
Tom and Margaret
Old 11-10-2014, 01:39 PM   #6
Thanks Tom, I'll go check the parts drawer and see if I can find it...
Old 11-10-2014, 03:56 PM   #7
Chris, I did the same thing because it didn't work without the filter. I assume I'm fine because I too saw pink in the filter area. It's amazing how well the filter cleaned out the antifreeze of the fridge.
CT Camper is offline   Reply With Quote
winter, winterize
