Old 12-30-2015, 08:35 PM   #1
jegstrup's Avatar
Operation of the step
For some reason, when I came home today, the electric front step has decided to start extending and retracting when I open the door. Normally, when I'm parked and set up, it stays extended.
Any ideas about this?
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 12-30-2015, 09:00 PM   #2
dan-nickie's Avatar
Turn the step switch by the door to off.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-30-2015, 09:03 PM   #3
jegstrup's Avatar
Haha! I must have but that when I was feeling for a light switch.
Thx a lot!
Old 12-31-2015, 04:25 AM   #4
dan-nickie's Avatar
Newbies! Just kidding.
I'm glad my extensive diagnostic skills work for you. :-) :-) :-)
Dan
Old 12-31-2015, 05:31 AM   #5
Fulltime in our Berkshire
KennyGolub's Avatar
You were supposed to have him remove the step motor first, and test all voltages with a VOM. Then remove the switch panel to make sure all connections were solid. THEN tell him about the switch
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 12-31-2015, 12:12 PM   #6
pashooter's Avatar
Don't know if my Pursuit has the same power step, but it works the same way - when on, it extends whenever you open the door & retracts when the door is closed, which I found very annoying when parked. Turning it off causes it to stay out, but the problem there was the light below the step was off as well (when the step is on the light comes on whenever the step is out). I ended up putting the step light on a separate switch from the step itself so I could turn the step off and still switch on the light at night.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2018: 10
pashooter is offline   Reply With Quote
Old 12-31-2015, 01:18 PM   #7
BobHanke's Avatar
Was considering running the step light off of the porch light switch. Found what seems to be a work light to the side of battery compartment area and hope to wire that to the porch light switch instead as we would often want both at the same time. If that light was intended to be used when working on fuses and house batteries under the steps, its location is not very convenient.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Shikibu
BobHanke is offline   Reply With Quote
Old 12-31-2015, 01:33 PM   #8
pashooter's Avatar
Here's what I did:
Our new 2016 Coachmen Pursuit 31BD
Old 01-01-2016, 07:38 PM   #9
Do a search for the step light fix. Dan did a nice job engineering and writing up the directions. If anyone has that link please post.
