09-30-2015, 06:13 PM
#21
09-30-2015, 06:25 PM
#22
I found a cover made for TVs that are kept outside or under a patio. It fits great, keeps water off and also had a pouch in the back to hold my remote.
-David
09-30-2015, 06:26 PM
#23
Originally Posted by glevron
Nice !! Did that model come with a shoehorn ? lol Looks like it just fit's nicely.
Joe & Lori
2014 Berkshire 390 RB-40
09-30-2015, 06:27 PM
#24
Glevron, nice. Where did you get your mount. Great idea!
Rich
09-30-2015, 06:30 PM
#25
Joe if that hurricane stays on course you might get a chance to see if the compartment leaks oh crap.
Wayne
Wayne
09-30-2015, 06:31 PM
#26
-David
David, sounds interesting. Where did you find it?
Rich
09-30-2015, 06:32 PM
#27
Yes this will be a good test.
Joe & Lori
09-30-2015, 07:41 PM
#28
Outdoor Entertainment Compartment
Rich, this is the mount I used, it's less than 2" when it closed! The tv is a 39" Vizio, it's the only one I could find that would work in that opening, Not gonna lie it's a snug fit. But it works great! Found it on amazon.
09-30-2015, 08:24 PM
#29
10-01-2015, 08:27 AM
#30
Nice install glevron. I however would like to caution you and anyone mounting anything on a cantilever. With RV parked, everything might be great however when on the move going over bumps, even a light weight item is going up and down like on the end of a pry bar. Eventually, it will take its toll.
I suggest that you place some ridged foam under the TV when travelling.
Gale & Hank- 2012 Berkshire 390BH
10-01-2015, 02:12 PM
#31
Good call Hank !!
Joe & Lori
10-02-2015, 07:58 AM
#32
IMHO any fix other than that external flap. It looks cheap.
Paul
10-02-2015, 02:35 PM
#33
Paul
I guess if it solves the problem, but I'm not crazy about the look either. It will be my last resort if needed after I try a couple of other strips.
Joe & Lori
10-02-2015, 03:37 PM
#34
Well, not my favorite look either, but I got it, so I'll flaunt it
Rich
10-05-2015, 01:35 PM
#35
I have the same water issue on my fuse box compartment below the drivers window. Water leaks at the hinge and puddles at the bottom of the door. Looked at three different units when buying mine and all three had the same problem with water pooling in the same spot, one even appeared to cause the door to begin to rot.
10-06-2015, 06:29 AM
#36
I don't open that door much but noticed a lot of water when I did.
Wayne
Wayne
10-06-2015, 07:29 AM
#37
I-RV, when the tv is closed its sitting on Velcro pads on the flat ledge above the radio. It's a tight fit & no weight on the mount!
