Old 09-12-2016, 01:13 PM   #1
Go Seahawks!
Subsailor's Avatar
Outside temp while driving
Hello all. I am kind of a weather geek and tend to pay attention the weather a lot. Since the Berk did not come with an outside temperature monitor (at least the 2013 model), if you have added one to your rig, what brand was it? Where did you put the temperature sensor?
Thanks, Glenn
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 09-13-2016, 08:17 PM   #2
62_inrightlane's Avatar
The area's temperature is a selectable statistic that can be displayed on my Garmin RV 760 LMT.
Marc & Jan
Molly, Abby & Katie | The Cocker K-9 Kids!|Toad 2014 Cadillac SRX
2012 Berkshire 360FWS, Brake Buddy Vantage|Wineguard Travler SK-3005
62_inrightlane is offline   Reply With Quote
Old 09-13-2016, 08:37 PM   #3
Bluepill's Avatar
$10 wireless indoor/outdoor digital display from Walmart. Velcro the outdoor sensor to an area that is open to air movement and protected from the weather. I put mine in the basement bay for the Propane tank. Works great.
2008 Itasca Meridian 37H
Old 09-13-2016, 08:41 PM   #4
kenandterry's Avatar
Glenn.....
Being that you have a Berk...you could place the outside sensor in the generator drawer somewhere. Unless the genny is running, it should give you a pretty realistic reading of outside.
I would suggest you buy a thermometer unit from Walmart....the kind that measures indoor and outdoor. Pick which ever model looks best for the indoor positioning of the unit. They have a variety of battery powered units to choose from.
Mine is in the propane tank compartment because I have a gas engine motorhome.....so up front is not an option.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-13-2016, 10:14 PM   #5
Berkshire 390QS
NO3putt's Avatar
Purchased a indoor/outdoor one and placed the outdoor sensor in the water bay. Really only monitor when temps are real cold.
2015: 188 days, 2016: 72 days, 2017: 95 so far
Skip
NO3putt is online now   Reply With Quote
Old 09-14-2016, 07:11 AM   #6
Go Seahawks!
Subsailor's Avatar
Thanks folks! The Walmart indoor/outdoor was the path I was thinking of, just wanted to check with others. I was also thinking the water bay would be a good spot for the sensor. I could mount the indoor display on Velcro and bring it in the house when I have the Moho put away for the winter and I could monitor water bay temps from inside the house to see if I need to put a heat source out there. -Glenn
Glenn and Darcy
Pacific Northwest
Old 09-14-2016, 07:08 PM   #7
I have an indoor outdoor unit but I just feel the window frame to see how hot is is... Arizona style, it's hot! Sometimes it's better to not know what the temperature is!
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 09-14-2016, 09:35 PM   #8
padcarroll
I bought an AcuRite system from Walmart. I used velcro to fasten remote unit in wet bay. There are more expensive units that will handle multiple remotes if you really want to know the true exterior temp. I was more concerned of the temp where all the water connections are.
Dave and Pam Carroll
Callie - 9 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 09-15-2016, 04:31 PM   #9
gasman94's Avatar
Got one from CW. Mounted remote in genny bay and temp gauge on dash next to speedo...
gasman94 is offline   Reply With Quote
Old 09-15-2016, 04:47 PM   #10
Indoor/outdoor with remote sensor here also. I velcroed the remote outdoor sensor in one of the garage compartments next to my slide controller. The surface it is mounted on is basically the fiberglass wheel well so there is no insulation between it and the outside. Where it is at the temperature never gets affected by sunlight heating effect. It is also in a dry compartment so it is out of the elements and I don't have to worry about it disappearing.
ShermanD is offline   Reply With Quote
