Old 03-02-2011, 06:56 AM   #1
Jet
Outside tv
Has anyone done an outside tv on Berkshire 390 bh?
Jet is offline   Reply With Quote
Old 03-02-2011, 09:13 AM   #2
tmmar's Avatar
No, but was thinking of buying a small LCD to keep in the compartment where the cable and elec. hook ups are located. I would then get a small collapsible table to put it on. Nothing exotic in the way of setting it up.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 03-03-2011, 06:31 PM   #3
Just did.
Ours is a 390QS. We did a 32 " TV in the side compartment. Worked out great and far less than the $1500 option.
blackttr is offline   Reply With Quote
Old 03-03-2011, 06:43 PM   #4
Jet
Could you tell me how and which compartment? And any arm etc
Old 03-03-2011, 07:06 PM   #5
I used the first compartment on the passenger side. It was equipped with a cable hookup and power outlet (we have a 2011). All I did was to remove the shelves that were there, and use the stand that came with the TV. I drilled two whole through the bottom of the compartment to hold the TV in place. I can still pull the TV if needed. Worked really well.
Old 03-03-2011, 07:17 PM   #6
Jet
Thanks for the input.... I will give it a try
Old 03-04-2011, 01:02 PM   #7
amarzano's Avatar
Any chance you can shot a few photos for us that are still trying to visualize?
Thank you!
Alex
2011 Berkshire 390BH-60
Cummins ISB 360hp/800ft-lbs DEF
Allison 3000
amarzano is offline   Reply With Quote
Old 03-05-2011, 06:41 PM   #8
JEM
TV
I have used the same setup as TMMAR suggested. I am probably going to cut two of the three shelves in the compartment with the cable outlet so that I can attached the base of the tv to the bottom floor of the compartment allowing me to close the door, hopefully there will not be too much vibiration to damage the tv, may put some kind of shock absorbing material between the tv base and the floor, still in the design stages Will send photo when finished.
Jim McAfee
JEM is offline   Reply With Quote
Old 03-07-2011, 12:42 PM   #9
I put a 32" LCD in and ran HDMI from the Sat and Blue ray player to the compartment behind the entry door. I removed the bottom shelf and mounth the TV on at piano hinge to the top shelf so the TV lifts up and we can still use the storage.
2010 Berkshire 390BH Bunkhouse
350 HP Cummins & MH3000 Transmission
1200 watts of Solar power
2 - KVH R6DX Dishes with DISH HD DVR
AB6FC is offline   Reply With Quote
Old 03-21-2011, 01:43 PM   #10
Jet
How did you run the hdmi cable?
