Originally Posted by planopat
I couldn't get a code using the dash switch but did get code 36 using the one on the gen. Can't be fuel level, there's 75 gal there. Air filter should be good, only about 50 hours on it but I'll check in the AM. Thanks.
My onan did the same thing...would start and run for a bit then die and give a fuel code error. Took off the fuel pump and tried it detached from unit. again ran till it overheated. ordered one thru amazon, perfect replacement,installed and life's all good again
