Old 04-19-2016, 11:00 AM   #1
I-RV's Avatar
Paint Color Identification Help
My Berkshire is the Warm Cashmere (aka 2012). I am trying to get a new water heater door panel painted, which has two the four paint colors of my rig. Myself and a body shop could not identify which two colors the panel has from the paint code chart (see codes pic). They did not understand the paint codes either.
I have enclosed the paint codes and picture of the heater panel along with a picture of my four colors.
I appreciate if anyone could identify the water heater door colors and also the FR paint shop, should I need to call them. Thank you in advance!
Hank
Name:	RV Paint Colors Pic.JPG
ID:	105428   Click image for larger version
Name:	Water Heater Panel.JPG
ID:	105429   Click image for larger version
Name:	Paint Codes.jpg
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 04-19-2016, 11:45 AM   #2
klucas's Avatar
I looked real quick on the sikkins web site. Looks like they have a color locator. Maybe there is a way to
Input color code and see a sample picture. This may help in figuring out what code belongs to what color. Good luck.
klucas is offline   Reply With Quote
Old 04-19-2016, 01:36 PM   #3
Berkshire 390QS
NO3putt's Avatar
We took our heater cover to an automobile paint supplier and they matched it perfectly using their computer.
Old 04-19-2016, 01:41 PM   #4
Director, FROG
F.R.O.G.'s Avatar
Hank
I'd think the codes you showed should be sufficient, but if you'll call Mitch Wirt at the Berkshire plant, he should be able to help you. It will help to give him the last seven digits of your VIN. You can get Mitch at (574) 295-2117.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 04-19-2016, 03:49 PM   #5
I-RV's Avatar
Thank you, Bob. I know that our forum is a great resource and thought I try that first, rather then bothering the FR customer service. I will call Mitch if I don't get some good answers, however.
Hank
Old 04-19-2016, 03:50 PM   #6
I-RV's Avatar
I already had tried the Sikkens web site and couldn't get anywhere. Maybe its me.
Hank
Old 04-19-2016, 04:40 PM   #7
Director, FROG
F.R.O.G.'s Avatar
I did Google searches on "universal paint code 62(d)" and on "spiral gray paint" under "images," and it appears to me that it's the paint used on your door. Monitors can show different colors, but it looks to me like a pretty close match.
Bob Byrne
Old 04-22-2016, 12:41 PM   #8
captnrick3's Avatar
Hank
I am painting a new WH door today for my Legacy. I took a picture of my Sikkens color chart, and a picture of my door to a local PPG automotive paint supplier, they matched it easily and I was able to buy .5 pint quanities of each color.
Did the first base coat an hour ago, came out perfect.
I just upgraded to the newest Girard tankless WH and of course the door is different.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 04-22-2016, 04:11 PM   #9
I-RV's Avatar
captnrick3 - Good advice. I have my panel into a paint shop and will probably be a lot more costly. How do you like the operation of the Girard Gen III. I can't believe how quite it is. It didn't like my pulsating MH pump however. I played with it and got the pulsating to stop. I replaced the Gen I, how about you?
Hank
cat
