Old 09-02-2014, 06:15 PM   #1
tmmar's Avatar
Paintless dent removal
Has anyone had any experience with a paint less dent removal service? I have a dent on the cap along the top edge of my coach and was thinking about using one of these services to remove the dent.
Thanks,
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-02-2014, 06:28 PM   #2
Kaadk's Avatar
A company I used to work for sold vision sensors that highlighted metal fatigue to a company that did paintless dent repair. That's about as much experience as I have with them.
But I can say this, a company that is going to use a $20,000 sensor to make sure it's actually smooth is better than one that's gonna eyeball it. (Probably more expensive too)
Edit:
It appears my old company has discontinued the old sensor, but for those of you interested in the technology I managed to come across a couple of old articles about it:
Vision system enhances inspection of automobile parts - Vision Systems Design
http://ntrs.nasa.gov/archive/nasa/ca...0020086717.pdf
Old 09-02-2014, 06:39 PM   #3
VinceU's Avatar
Thanks,
Tom
A self contained "auto body shop" used to come to our company parking lot and solicit repairs to small parking lot dents. They did a great job and quickly but that was in sheet metal. Not sure if they can do 'glass. That was in Bala Cynwyd PA probably 10 years ago. The concept works however.
Old 09-02-2014, 06:42 PM   #4
prof_fate's Avatar
call any car dealership, they all use the paintless dent wizards.
only works on metal.
must have access tothe backside of the panel.
it works and is AMAZING. And cheap.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 09-02-2014, 09:19 PM   #5
Mmnsc's Avatar
Tom
I had it done on a car that was heavily dented by hail. You would never know there was a dent and the paint was totally intact. Is the dent in a metal portion of the coach? Not sure if they can also do aluminum as I have only seen it done on steel sheet metal.
Marty
Mmnsc is offline   Reply With Quote
Old 09-02-2014, 09:32 PM   #6
Oklahoma Proud
MillerTime's Avatar
Thanks,
Tom
Have a pic?
I work in the collision industry in Oklahoma, so we know a little about hail in our state.
I should be able to tell you whether it will push or glue pull if I can see a good pic and a size reference pic (ie. quarter, beer can etc.)
Oh, and yes we use or do PDR quite often, some will work, and some not. Just kind of depends on the metal and the physics or type of dent it is. Dents on corners are alot harder to fix, due to the fact the metal is work hardened from the corner already, so dents on corners are usually much harder to make than on a flat surface......and also sometimes harder to fix as well.
Old 09-02-2014, 09:39 PM   #7
Salt Shaker's Avatar
Steel and aluminum. PDR is the only way to fly. I dodged a tornado in my brilliant black hemi charger. The downside of outrunning it was hail made it look like a golf ball on the other side of the storm. Insurance covered PDR. It actually cost more than body filler and a reprint. If I remember it came in at about $4800. Boy did she look nice when done, better and straighter than factory.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 09-03-2014, 10:36 AM   #8
Campin Cajun's Avatar
I also used a company called Dent Works on my Jeep, it was a kink dent on the top curved corner above the front fender. I never thought they could make it look good. I was wrong, I could not point out the dent after he was done.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-03-2014, 10:55 AM   #9
tmmar's Avatar
Here's a picture of the dent I would like repaired. It looks like it is about 6" long and there is no access to the rear of the dent. I believe that the cap is made of aluminum. Don't know if something like this can be repaired using the paint less dent removal technique.
Tom
Tom and Margaret
Old 09-03-2014, 11:09 AM   #10
Kaadk's Avatar
Generally, paintless dent removal works by getting to the backside of the dent, and gently lifting the metal back into place. If they can't get to the backside, then it's doubtful.
Old 09-03-2014, 11:17 AM   #11
They would have to use a plunger/suction cup type puller to get that dent out.
Old 09-03-2014, 01:13 PM   #12
Oklahoma Proud
MillerTime's Avatar
Aluminum is harder to work out, it retains its memory more then steel.
They could try to glue pull it if its not too strong of material. Nobody uses suction cups to pdr. They hot glue a plastic tab and jerk it off with a slide hammer.
Its worth a shot!
Old 09-03-2014, 08:42 PM   #13
Man, that looks pretty bad. May need old fashion body and paint work.
RodneyD is offline   Reply With Quote
Old 09-03-2014, 08:57 PM   #14
Surveyor Mike's Avatar
Most good PDR tecs will come out and look at the dent and give you a price, or tell you they cannot make it "undetectable". I agree, a glue pull is the way to go. Some guys will want to drill hols for access, don't do it! If it cannot be glue pulled, call a paint shop.
2004 Surveyor 291 ultralite
2008 Ram 1500 quadcab Hemi
Surveyor Mike is offline   Reply With Quote
