Old 08-15-2016, 02:43 PM   #1
62_inrightlane's Avatar
Passenger Side Mirror Arm Adjustment
Has anyone adjusted the arm outward to give a better rear view down the passenger side of the coach. When driving, with mirror housing in current position half the view is blocked by the awning arms folded against the side of the motorhome. There is a bolt at the top of the arm, however when I loosened it the mirror arm would not budge. Anyone have any ideas?
Name:	ImageUploadedByForest River Forums1471290181.923322.jpg
Name:	ImageUploadedByForest River Forums1471290226.006269.jpg
Marc & Jan
Molly, Abby & Katie | The Cocker K-9 Kids!|Toad 2014 Cadillac SRX
2012 Berkshire 360FWS, Brake Buddy Vantage|Wineguard Travler SK-3005
62_inrightlane is offline   Reply With Quote
Old 08-15-2016, 06:51 PM   #2
15berkxl's Avatar
Yes loosen the top bolt and then swing the arm out but be careful not to go out too far or it will become a branch or sign finder.
When you have where you want it make sure you tighten the bolt good or the mirror will move on you when you get up to highway speeds (from experience).
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 08-15-2016, 07:23 PM   #3
Mmnsc's Avatar
You need to loosen the bolts on top of the mirror and the bolt on top of the arm closest to the motor home. Once the 2 bolts are loosened you need to rap the top of the bolts so that you can move the arm and mirror to make the adjustments. Tighten the bolts slightly so you can make the adjustments and once you have the proper position tighten up the bolts. It takes 2 people to adjust. Sit in the driver's seat and have someone move the mirror and arm until you can see what you want to see. It might take a couple of tries to get it comfortably adjusted.
Mmnsc is offline   Reply With Quote
Old 08-15-2016, 07:35 PM   #4
Wayne
Wayne, I loosened that bolt and the arm wouldn't move. I didn't put much pressure trying to move it. Should
It move fairly easily or will I need to put a little muscle behind it?
Does the arm need to drop down out of some type of locking system to be moved? When I loosened the bolt it rose up and the arm didn't drop down.. Is it held in place similar to how a windshield wiper arm is held in place with a ribbed locking system?
Marc & Jan
Old 08-15-2016, 07:44 PM   #5
Mmnsc, thanks you answered my question while I was composing it. I will dig out my rubber hammer and drive the loosened bolt down allowing me to make the adjustment.
I think moving it out a couple of inches will give me a much better view down the passenger side of the coach.
Marc & Jan
Old 08-15-2016, 07:56 PM   #6
edgewant's Avatar
As best I can recall I had to tap on the bolt with a socket extension and hammer to loosen it up.
2013 Berkshire 390RB-60
Toad: 2002 Jeep Wrangler
edgewant
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 08-16-2016, 12:50 PM   #7
Mirror mount torque
I've adjusted the position of the Driver side mirror to be as close to the coach as possible without being blocked by the left pillar don't want to knock any Customs agents on the head!
And, I moved the Passenger side mirror out to the point where the right pillar would block the view. I wanted to get a better view beyond the slides.
When I did this, I found that I needed to tighten the bolts to 15 ft lbs in order to prevent the wind from bending the mirror out of position. I wasn't sure how strong the fittings were, since some mirrors are made on pot metal frames. So, 15 ft lbs is the least tightening that worked. And it was about the same as they came from the factory with I checked while loosening one.
Gordon Sick, Calgary
2015 Berkshire 34QS
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 08-16-2016, 04:44 PM   #8
Thanks, great tip!
Marc & Jan
Old 08-19-2016, 08:31 AM   #9
joeplante's Avatar
It seems that you have to reset the cameras within the mirrors also once you get them adjusted to where you like them . mine are currently cock-eyed so I need to rotate them within the mirror .
2016 Berkshire XL 40 BH: Travels with Tosha my wife and 4 boys Colton 8 yrs, Hunter 4 yrs, JoJo 3 yrs, and Wyatt 2 yrs . Season 1 logged 5100 miles and 36 nights.
joeplante is offline   Reply With Quote
Old 08-23-2016, 05:45 PM   #10
Partially loosen the nut, sprayed WD40, let sit overnight. Mirror was loose next morning. Be careful. The mirror is heavy.
parduelay is offline   Reply With Quote
