Originally Posted by po 185
has any one replace the porch light lens over the door ?. it is amber and does not produce that much light. would be better if it was a white lens. so if you have let me know where to get one
I just replaced the fixture with a motion sensor star light 1000, comes with a 200 lum led bulb and a clear and orange lens. I think I paid 55.00 or so, But it's nice when you come back at night the sensor could pick you up at 50' and turn on then go back off in about 3 mins. Plus any one that comes near your door at night it will light up. It has an adjustable distance screw so you can set it at 10' if you want. Will not pick up small animals and such. If you don't want the motion sensor you can just use it as a light
On off and on again motion sensor or just on like the one installed same switch and two wires. Check Amazon or ebay.I put 4 on mine 2 porch lights added one and both scare lights those are the #2000...
