Old 05-27-2013, 11:49 AM   #101
ernest917's Avatar
Amen!!!!!
ernest917 is offline   Reply With Quote
Old 05-27-2013, 12:19 PM   #102
Tonk Mom's Avatar
Ed is finishing up the installation now. He bought a battery specifically to use for the freezer and installed the electrical in the basement for AC/DC.
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 05-27-2013, 12:29 PM   #103
ernest917's Avatar
That's great... Can't wait to see pictures....
Old 05-27-2013, 07:07 PM   #104
Tonk Mom's Avatar
All installed!
Name:	1 (mounting frame).jpg
ID:	31459   Click image for larger version
Name:	2 (Frame outline with drilled holes through basement floor.jpg
ID:	31460   Click image for larger version
Name:	3 (Frame with slides).jpg
ID:	31461   Click image for larger version
Name:	4 (AC and DC connections).jpg
ID:	31462   Click image for larger version
Name:	5 (Frame installed).jpg
Name:	6 (Frame installed).jpg
ID:	31464   Click image for larger version
Name:	7 (AC and DC connected).jpg
ID:	31465   Click image for larger version
Name:	8 (It's in and running).jpg
ID:	31466   Click image for larger version
Name:	9 (All done).jpg
Jill
Old 05-27-2013, 07:33 PM   #105
billygo3251's Avatar
Great job
billygo3251 is offline   Reply With Quote
Old 05-27-2013, 07:52 PM   #106
ernest917's Avatar
Tonk....
Ed did a fantastic job... Looks really great...
(Don't forget to lock the slide in place or the fridge will slam into door when you turn a corner and could force it open.. You may have already taken care of that but just wanted to make sure)
By the way: great looking fridge.... Looks familiar... lol..
Old 05-28-2013, 02:14 PM   #107
Tonk Mom's Avatar
Originally Posted by ernest917 View Post
Tonk....
I will tell him, thank you!
Ah, lock the slide, glad you said something, I don't know if he did, but will ask.
It is a nice fridge. I like the one the guy above here posted. It's bigger.
Jill
Old 05-28-2013, 02:15 PM   #108
Tonk Mom's Avatar
Originally Posted by billygo3251 View Post
Great job
Thanks! I will tell my husband.
Jill
Old 07-20-2013, 01:25 AM   #109
ernest917's Avatar
Well, we are about to start our fourth week out and I'm pleased to report the our ref/freezer is working like a champ!!!! We left on June 28th and I set the freezer temp at 20 degrees... It has only varied up or down 2 degrees the entire time and everything has been frozen solid... It switches from AC to DC automatically and hasn't missed a beat ....
I did have one issue I had to correct while on the road tho... One I loaded it totally full of frozen food, the weight caused the wooden tray to sag in the middle and drag on the compartment rubber gasket when being pulled out or pushed in... Solution: a piece of angle iron at front and back of tray took care of the problem...
It's kinda fun to pull up next to some of those Newells, Provosts, and the like and watch their faces when our Berkshire shows its Ref/freezer to them.. Z
Old 07-20-2013, 07:37 AM   #110
jimh's Avatar
I had to overnight w/o shore power and my optima battery ran mine for 10 hrs before I plugged back into the truck. It was a pleasant surprise.
jimh is offline   Reply With Quote
Old 07-21-2013, 03:33 PM   #111
ernest917's Avatar
Well I did discover that since I have my ref/freezer plugged into an AC outlet that is effected by a ground fault outlet in the coach, you need to be aware that the GF outlet is thrown....
Almost lost my food because of that.... Something triggered the GF and also blew the DC fuse.... Fixed both and up and running again...
Old 01-12-2014, 03:13 PM   #112
Tonk Mom's Avatar
For Ernest
Ernest~
We are getting ready to use the RV and freezer finally, but the fuse for the freezer keeps blowing. What size are you using? We had a 5 and it blew, put in another and it also blew.
Jill
Jill
Old 01-12-2014, 10:47 PM   #113
ernest917's Avatar
Tonk....
I switched my 5 amp for a 7 amp and haven't had a single problem...
