Old 05-09-2013, 02:28 PM   #81
Tonk Mom's Avatar
I think so too; it looks great!
Jill
Jill and Ed and the kitties
1998 Coachmen Leprechaun 31Q
Tonk Mom is offline   Reply With Quote
Old 05-09-2013, 09:08 PM   #82
Tonk Mom's Avatar
I got this message when I responded to your PM.
ernest917 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Jill
Old 05-09-2013, 09:19 PM   #83
ernest917's Avatar
Try it now.....
ernest917 is online now   Reply With Quote
Old 05-12-2013, 10:12 PM   #84
Tonk Mom's Avatar
You are all full up again and I can't reply to you.
Jill
Old 05-12-2013, 10:19 PM   #85
ernest917's Avatar
Now try....
Old 05-16-2013, 05:09 PM   #86
ernest917's Avatar
Well, we leave tomorrow for a 4 days trip where we will give the new freezer set-up its first test...
I plugged the freezer into both AC and DC yesterday afternoon and hit the FF switch (fast freeze) and within a few hours it was reading -10 degrees... Then reset temp to 10 degrees and placed some frozen ice cream bars in it for an over night test....
Went out after lunch today to check thing out and ice cream frozen solid and temp reads 12 degrees....
Just loaded it up with things we will need for the trip and of course with the lid up the temp went up to 17 degrees.... Closed it up and checked 15 min later and temp was back down to 10 degrees....
So far it looks like I'm going to really be pleased with it... Guess I will know more when I return Tuesday after running it on both AC and DC...
Old 05-19-2013, 08:30 PM   #87
Family Man with an RV
doctormdj's Avatar
Send a message via Skype™ to doctormdj
Ernest917, I have this in my basement... but think I might upgrade and go your way. Although this works great and was a cheap addition, I think you got something there! Gonna have to copy you too! :-)
doctormdj is offline   Reply With Quote
Old 05-19-2013, 08:50 PM   #88
ernest917's Avatar
Doc....
Feel free to copy away....
We are currently down in Houston and its hot - BUT... The freezer is performing like a champ... Temp hasn't risen above 12 degrees and everything's frozen solid...
Old 05-19-2013, 09:29 PM   #89
Mbh818's Avatar
Doc-
Would you mind sharing how you installed the fridge? Ernest, you did a great job and it looks great, just a bit beyond my price range. Would love to put a small fridge in the basement for the kids. Doc- where to you get the electricity from? Did you drill thru to the front compartment that had the outlet in it? Looks like you have it raised so you can open the door. Did you bolt a platform through the basement floor? I can also see a ratchet tie to keep is secured. Smart smart.
Thanks for any help you can provide.
Mike
Mike Hollar
2014 Berkshire 390BH-40
2012 Chevy Equinox - TOAD
Mbh818 is offline   Reply With Quote
Old 05-19-2013, 09:59 PM   #90
doctormdj's Avatar
Mike -
Yepper. Super easy to do and easy to remove if you need to replace it for any reasons. I had to pull mine out for a little but while we installed one of those Central Vacum systems... Now that was a cool add on. My coach is in the shop right now having a new cooling unit put on the Dometic Frig so it's not at a spot I can get to it to shoot some pics for you and give you the 411. In short... yes it is raised and carpet wrapped. The block under the frig is attached to the basement and the staps are under the bottom of the base and wrap over the frig. 110 is done through an extension cord actually and run from the basement where we have the TV. If you can wait until the end of the week I'll get you a complete diagram, parts list and photos to walk you through. Take a trip to home depot, buy a small frig and your done for no real money at all.
On your 2014 did you get the outside TV as well?
