Old 02-28-2019, 01:43 PM   #1
Eagle5's Avatar
Power Cord Reel ?
So the Berkshire ‘19 34QS that I have doesn’t have a power cord reel. Not sure if the older ones had them OR if the XLs come with them either.
So my first question would be ... if the XL models have them, which brand/type did FR choose for this?
And secondly, are there any Berk owners out there who added one after the fact? Which did you choose and how is it working, etc? And was it even worth it?
I don’t mind the lifting of the cord or anything but it does get sandy and messy handling it. And I thought it would be nice to have one to keep the bay area cleaner and more organized
2019 34QS with no ladder!
Eagle5 is offline   Reply With Quote
Old 02-28-2019, 01:50 PM   #2
Lacey's Spring, AL
formerFR's Avatar
question: do you have to plug the coach end into an outlet on the outside of your coach wall - or is the coach end already 'hard wired' to the ATS(auto transfer switch) within the electrical bay?
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 02-28-2019, 04:14 PM   #3
The 2016 xl I have does not have one, and it’s hard wired in so it’s a nonstarter for a reel I’m thinking. I’ve run into the same thing. The cord is pretty thick and stiff on mine so in cold weather I have to really use English on it to fold into that space. I think I read somewhere on the forums with other brands where folks changed out the cord for a high quality but more flexible brand. Wouldn’t help with the mud and crud issue though.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 02-28-2019, 04:45 PM   #4
cavie's Avatar
Do a search on this forum and see if you really want to deal with a power cord real. As a 50 year electrician I can tell you I want no part on one. Moving electrical contacts are just something else to go bad at the wrong time and you would need a tech to fix it on a Sunday/holiday afternoon. Purchase 2 cords of good quality and flexibility and plug them together.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-28-2019, 04:47 PM   #5
Eagle5's Avatar
Ok no prob. No reel. Clearly not worth it
Old 02-28-2019, 05:22 PM   #6
CZNEDY's Avatar
I have a 2018 34QS and there really isn't any room in the compartment for a reel anyway.
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 02-28-2019, 05:25 PM   #7
Manual Power Cord Reel
I am considering getting this one on Amazon.
Primarily to free up some space in my electrical storage bay.
https://www.amazon.ca/gp/product/B00...K6Y9EEQB&psc=1
2018 FR Berkshire XL 40 C
2016 Jeep Cherokee Trailhawk
BlueOx Avail TowBar
raidernation is offline   Reply With Quote
Old 02-28-2019, 05:25 PM   #8
Eagle5's Avatar
Yea I figured I’d have to get a low profile one, or nothing. But sounds like there’s more BS involved than is worth it.
And my compartment is even smaller since I added the Progressive EMS box.
Old 02-28-2019, 05:39 PM   #9
Lacey's Spring, AL
formerFR's Avatar
While my rig originally came with an 'external' outlet wall connection for the shore cord, I removed the outlet and wiring and hardwired it back into the DEF bay, where it feeds up into the coach/ats... and the nice fact is that this DEF bay provides just the right 'reel' for the cord - around the DEF tank!
now, when I arrive, I simply take out only the footage of cord required to reach the pedestal, sometimes less that 3', and sometimes the cord doesn't even touch the ground. easy, and a totally 'worth it' mod, versus the old school handling of the whole cord, removing it from the main bay, every time you needed to hookup, with the 'rest' of it laying on the ground.
The Turners
Old 02-28-2019, 07:23 PM   #10
Dragonship Captain
Oscarvan's Avatar
I don't think that's going to work on my BERK.
I thought about a reel, for about 2 seconds. My cord needs run from 5 to 75 feet. I have the leftover from when I shortened it for the Hughes and I have 2 fifty footers which I bring as needed. (Usually only one unless I'm going a certain place.)
Reel is money, takes up space. Nope.
I don't mind handling the cables. Twist/coil into the compartment with a rag in one hand wiping as I go. Put the tub with hoses on it, close the door. Done.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
power
