Old 08-10-2015, 08:48 PM   #11
Check out online inverter store
Jerry. Vietnam vet.
jgahlhoff is offline   Reply With Quote
Old 08-10-2015, 09:03 PM   #12
Campin Cajun's Avatar
Jeg, that repair guy is blowing smoke up your.......
How old are your batteries?
Have you checked the water level in them?
Your batts should charge while you are traveling, may have a bad cell or two in the batts.
Take it to another repair shop.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-10-2015, 10:40 PM   #13
Total BS. What in the world are you trying to run that needs a bigger inverter? I don't see any way to spend 8500$ on a inverter. You need a better repair guy.
Old 08-10-2015, 11:02 PM   #14
jegstrup's Avatar
Correction, mine is 1200 watts, Magnum mm1212
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 08-10-2015, 11:02 PM   #15
accumack's Avatar
Did you check the circuit breaker on the inverter?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 08-10-2015, 11:20 PM   #16
Berkshire club
Berkshire Driver's Avatar
our 14 has a MS2012 2000 inverter 3300 surge with the residential frig and does charge on chassis alternator while engine is running .
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 08-11-2015, 01:21 PM   #17
Why do you need a bigger inverter? Are you thinking that you should be able to run AC on inverter? We has never had an issue with our 2012. The only time we ever use our inverter is at night for TV if we are dry camping and for charging our phones. There is plenty of power for 2 TVS and DVDs and a few phones. If you need more juice ... fire up the gennie
lefaivre is offline   Reply With Quote
Old 08-11-2015, 02:19 PM   #18
jegstrup's Avatar
I rarely ever switch the inverter on. The problem seems to be more about the charger, the fact that all of the power(ac) also comes thru it, the voltage loss from using ext cords, etc. I'm fine with that part. What I disagree with is a repair shop wanting $8500 to install a larger inverter that only costs around $2000-2500. I'll take the chance of doing it myself before I pay $6000 in labor!
Old 08-11-2015, 02:26 PM   #19
What private school does your repair guy send his kids too. Ask him that?
Old 08-12-2015, 06:45 PM   #20
If you feel your issue is on the charging side, it is my opinion that this is a malfunctioning charger rather than an undersized charger. I have on many occasions charged my house batteries both on Genet and shore power with both AC units running, 2 TVs and 2 DVD.
If you are not able to do this, I would first check your batteries and then check your charging system.
The only time I have any had any issues is when I am dry camping in very hot weather and am charging batteries without opening up battery bay. I have had issues with over heating. Otherwise ... no problems
