Old 09-22-2016, 02:49 PM   #1
tmmar's Avatar
Progressive EMS PT50
I have had this surge protector for several years now and I usually plug the protector in, turn on the breakers, and let it go through its cycle of checking the power at the pole before turning the breakers off and plugging into the protector. The last couple of days, the protector makes a clunking noise after I plug it in. It never did this before but it seems to be operating properly otherwise. I called Progressive and the tech said that it was normal.
Has anyone else who has this protector experienced it making a clunking noise?
Thanks for your input.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 09-22-2016, 03:21 PM   #2
Mine too
Mine makes a definite clunking after it goes through its cycle and decides all is well and allows power through. Sounds like a relay clicking in. Mine has always done that.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-22-2016, 03:28 PM   #3
tmmar's Avatar
Thanks. My concern is that mine has never done that before and I have had it for several years now.
Tom and Margaret
Old 09-22-2016, 03:30 PM   #4
I understand
I fully get it. We don't like when things change in our rigs after so many years. Good news is the 50 has a lifetime warranty.
Old 09-22-2016, 03:39 PM   #5
I have both the hard wired EMS-HW50 and the plug-in EMS-PT50. Both of them make the clunk/click sound after the delay.
That sound is the relay. Inside, there is a big relay that is spring loaded. The springs keep the relay open which prevents power from passing to the coach. After the delay and all is good, the relay slams shut to pass the power on. I assume the relay is closed magnetically.
I would bet yours has always done it but you just didn't notice.
325BH is offline   Reply With Quote
Old 09-22-2016, 04:29 PM   #6
15berkxl's Avatar
X2
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 09-22-2016, 05:11 PM   #7
tmmar's Avatar
If mine has always done this, it has done it very quietly. It has been very noticeable the last 2 days. I have never heard it before the last night.
Tom and Margaret
Old 09-22-2016, 05:16 PM   #8
Mmnsc's Avatar
Tom
Didn't you get your ears cleaned recently LOL
Mmnsc is offline   Reply With Quote
Old 09-22-2016, 05:29 PM   #9
tmmar's Avatar
No. But I did put new batteries in the hearing aids I don't wear!
Tom and Margaret
Old 09-23-2016, 12:58 PM   #10
fredhardy's Avatar
Tom - we have the same make and model rig. Whenever I plug into shore power, I get that clunk also. It's been that way since I bought it. I have always thought it was a normal connect/disconnect sound.
But I don't have the Surge Protector yet.
Regards,
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
