Old 04-23-2016, 06:55 PM   #1
Fulltime in our Berkshire
KennyGolub's Avatar
Propane connector
I have a propane grill/smoker with the regulator that connects to a 5 pound propane jug. What do I need to use the propane connection in the basement of the Berk?
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 04-23-2016, 07:49 PM   #2
accumack's Avatar
I got a hose from a propane dealer with a quick connect.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 04-24-2016, 08:09 AM   #3
I-RV's Avatar
Ken, I am sure you will hear from Dan. I followed his instructions which had links to all the necessary purchased parts, and it works beautifully. You will start with removing the grill's regulator since the Berk's propane outlet is low pressure.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is online now   Reply With Quote
Old 04-24-2016, 08:11 AM   #4
tmmar's Avatar
Ken,
You would, as accumack stated, need a hose with a quick connect to connect to the valve in the basement. You would also need to remove the regulator from the smoker and get either a quick connect set up or just a connector to connect the hose to the smoker.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-24-2016, 08:18 AM   #5
KennyGolub's Avatar
Originally Posted by tmmar View Post
Ken,
So the regulation is already handled on the coach ? All I need is some quick connectors for the coach and put one on the grill after removing the regulator on the grill ?
Thanks.
I'll look for the thread on doing this.
Ken & Laurie
2016 Chevy Colorado
Old 04-24-2016, 08:27 AM   #6
tmmar's Avatar
Yes, the propane output from the Berkshire tank is regulated.
Tom and Margaret
Old 04-24-2016, 10:00 AM   #7
dan-nickie's Avatar
Ken, I would have linked to my instructions but they were specifically for a Weber Q100. But I think you understand now. You have to remove the regulator and get a hose with quick connect to connect to the coach. The coach connector is already regulated down to low pressure.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-24-2016, 03:36 PM   #8
KennyGolub's Avatar
Great guys. Thanks for the info.
Ken & Laurie
2016 Chevy Colorado
Old 04-26-2016, 07:24 PM   #9
Thanks You guys just answered my same question.
james m rainey is offline   Reply With Quote
propane
