Old 06-25-2013, 06:11 PM   #1
Propane Quick Connect
There is a propane quick connect locates in the fourth bay on the passenger side of my 390BH. Has anyone used this? I need to know what it is regulated at I want to get a hose so I can run my grill but the grill has a regulator on it already. Do I have to remove the regulator off the grill or just leave it on?
csichoice is offline   Reply With Quote
Old 06-25-2013, 07:28 PM   #2
I wish I had an answer, because I have the same concerns. I was thinking of using an outside fireplace but I'm not sure of the output pressure.
JJ
JJvike is offline   Reply With Quote
Old 06-25-2013, 07:38 PM   #3
Best have a propane hose "expert" help with it, because of the plethora of different connectors and are NOT compatible with each other. Took me about 3 incorrect configurations, until I got it right.
But removing the regulator from the grille is the basic thing that has to be done. Otherwise you're "double regulating" the propane. My Weber works great off that connection in the fourth bay.
Boowho??
boowho is offline   Reply With Quote
Old 06-25-2013, 07:40 PM   #4
Phat Phrog Stunt Crew
elind's Avatar
JJ
The quick connect gas line has 1/2 pound of pressure or 11 column inches. You will need to take regulator off the stove line. Finding all the connectors to make it work could be fun. Good luck!
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 06-25-2013, 07:48 PM   #5
Thanks! That was quick.
JJ
Old 06-25-2013, 07:58 PM   #6
rip
rip's Avatar
For examples of quick-connect high pressure and low pressure hoses and fittings, try this BBQ propane pit company...
Gas Quick Connect Hose / Gas Quick Connects Gas Hose Systems
I got my hose assemblies and fittings there.
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 06-25-2013, 08:21 PM   #7
Campin Cajun's Avatar
Thanks for that link rip.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 06-26-2013, 03:12 PM   #8
rip
rip's Avatar
You're welcome. They (Tejas Smokers) help educate you on the proper quick connect male/female and have ready-made quuick connect hose assemblies (I needed the low-pressure ones).
I had some difficulty finding a selection of the male/female quick connects at local specialty stores, however Lowes and Home Depot did have various 3/8 sae flair to 1/4 npt adapters much cheaper than TS.
Good luck with your conversions. I did not know it at the time, but I was smart to buy a propane bbq grill with an external regulator on a short hose. That made my quick connect project for my stainless pit a lot easier than those with internally regulated pits. I got lucky with my particular pit. By reworking that external hose connection, I can now quick connect my pit to my RV with an extension hose or quick connect to my portable propane cylinder under my folding camp table, nice flexibility.
Ray
Old 06-26-2013, 05:29 PM   #9
RKC02's Avatar
Wow! Sure glad I read this forum! I thougt that was an air line connection. Good thing i didn't try it yet!
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 06-26-2013, 09:36 PM   #10
Himcules's Avatar
if you have the on demand water heater, watch your propane flow to your stove. i noticed when i hooked my 2 burner camp chef stove to the quick connect on my 390bh (hose without any regulator), i would see the burners fluctuate whenever the water heater kicked on while my wife was inside washing dishes or whatever in the sink. on low, my camp chef spluttered and cut out a few times because of this irregular flow. i had to switch to my standby portable tank and the regulated hose for that.
i will try it again and monitor some more to make sure this is indeed what is happening... i'll probably test with the burners in the stove too...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
