Old 11-15-2015, 11:25 PM   #31
2011 Berkshire 390BH
Superchief's Avatar
I figured I better post, so that Marine Phil is "sitting" in the middle of a bunch of Bubbleheads (Submarine Sailors)!!!!😂😂😂😂👍
PS - Phil you are the "hard striper" among us!! I would follow you anywhere, my friend!!!
Craig
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 11-25-2015, 12:56 PM   #32
BamaBob's Avatar
Originally Posted by Superchief View Post
Saw this on another thread, but this explains most of us: "What can I say, I like 'em tight. I did scare the GF when I tried to rig the TT for silent ops by turning off the A/C and unplugging the microwave, rigged for dive by shutting all the doors and windows, but she really doesn't like when I tell her we are hot racking and I call her my "rack mate". Damn civies..."
I just saw this post Craig - you are hilarious!!
I guess you COULD say you are Hot Racking in the Berkie
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 11-25-2015, 01:00 PM   #33
BamaBob's Avatar
I figured I better post, so that Marine Phil is "sitting" in the middle of a bunch of Bubbleheads (Submarine Sailors)!!!!����������
Craig
USAF Combat Control here...Called in many a package for my BIA in the USMC (BIA=Brothers In Arms)
You Bubbleheads are doing it right though. Much better than the guys n gals on the Aircraft Carriers!!
Because...
You Know what a Combat Controller Calls An Aircraft Carrier?
A TARGET
Old 11-25-2015, 01:17 PM   #34
oldkeywest91's Avatar
There is only two types of vessels...Submarines and Targets
oldkeywest91 is offline   Reply With Quote
Old 11-25-2015, 11:32 PM   #35
I have a 2012 390bh 60 with aluminum rims and 255 tires. Do I have a problem that needs to be dealt with?
lefaivre is offline   Reply With Quote
Old 11-26-2015, 12:46 AM   #36
baddmann's Avatar
There are multiple threads discussing this. Do a quick search and you will see the process to check and see if you have an issue. First thing is to get it weighed (CAT scale at a truck stop is easy).
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 11-26-2015, 07:20 AM   #37
accumack's Avatar
Get your coach weighed front axle and rear axle. Full fuel, and propane, empty fresh, gray and black water tanks and nothing in the coach. Report back to us. Some 390 bh units had a problem but not all.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-26-2015, 07:54 AM   #38
I-RV's Avatar
May I add that you just don't have to be over-weight to have a problem. After all the motorhome should carry passengers, belongings and some cargo. I advise empty weight weighing be done with 1/2 tank of fresh water and two passengers. This has be okayed by Randy and is only realistic.
I believe that any 40 ft.Berkshire with tile floors and a 10,410 lb front axle, should get the upgrade, The front axle is the steer axle and FR is most concerned about it, as you should.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-26-2015, 10:27 AM   #39
Thank you ... my MH is now put away for the winter and the snow is starting to fly. Will not be taking it out until spring.
My unit has all of the upgrades including tile floor and wash/dryer.
Will follow the instructions above.
If it turns out that there is a problem ... is FR footing the bill to correct the problem?
If so ... what is the process
Old 11-26-2015, 11:24 AM   #40
accumack's Avatar
Talk to Randy with your weights Mine took 5 months get setup and done. It was done last week.
Ham KG5LTL.
2013, dealer, weight
