Old 11-29-2015, 04:43 PM   #51
Paul ... not sure if you are referring to me. How can we update our signature.
lefaivre is offline   Reply With Quote
Old 11-29-2015, 08:38 PM   #52
Go Seahawks!
Subsailor's Avatar
Hello lefaivre, if you want to update your signature or anything else just go up to the "User CP" on the upper left and there is a pull down to update all of your info.
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 11-30-2015, 07:47 AM   #53
That option is not available on my phone .... will need to do it from a desktop
Old 11-30-2015, 12:28 PM   #54
mikeborny's Avatar
Just weighed my coach with full fuel and 2/3 propane and it is at 10520 front and 17080 rear. I have a 2014 that has the 12,000 front axle. I am a little shocked that my specs show a 17,500 limit on rear axle. 1900 lbs for cargo and gear and water is not great!
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 11-30-2015, 12:52 PM   #55
Campin Cajun's Avatar
Mike you are really good on the front axle. That rear axle weight is mysteriously the same as mine is. Spooky.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-30-2015, 01:27 PM   #56
Airdale's Avatar
"The FMVSS have requirements for the manufacturer to use proper tires and rims for the gross axle weight rating (GAWR) and the gross vehicle weight rating (GVWR). The manufacturer may determine the GVWR by adding cargo capacity (if any) to the curb weight of the vehicle as manufactured. The wise consumer, before purchase, will determine if the vehicle has sufficient cargo capacity to carry the weight of water, additional equipment (such as televisions, and microwave ovens), and luggage. The manufacturer’s certification label must show the GVWR. The GVWR must not be exceeded by overloading the vehicle. There is little the government can do to assist a consumer who has purchased a vehicle that has insufficient cargo capacity for its intended use."
NHTSA said that.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 11-30-2015, 06:52 PM   #57
accumack's Avatar
The limiting factor on the rear axle is the Allison 2500 transmission. The axle I believe is the same as the 3000.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 12-09-2015, 06:37 AM   #58
ccupton's Avatar
Just weighed my coach. 2016 38a. Front 10,120. Rear 17,600. Called FR and was told not a problem. 1/2 tank water, 3/4 fuel, empty black and grey.
Chris & Carol
2016 Berkshire 38A
2014 Honda CRV
Chris & Carol
2016 Berkshire 38A
2014 Honda CVR
Blue Ox base plate & tow bar. Air Force one Braking system.
ccupton is offline   Reply With Quote
Old 12-09-2015, 10:31 AM   #59
mikeborny's Avatar
I think i have had my tires at a little too high pressure for my weights. At 10,500 front and 17,500 rear what are most of you keeping your tire pressure at. I will assume loaded I would be adding another 800-1000 lbs.
Old 12-09-2015, 12:23 PM   #60
Need more info. What size tires do you have. Do you have a 4 point weight. You really need to have a 4 point weight to see what corner is heavy. You also need a loaded weight without guessing.
2013, dealer, weight
