Old 11-14-2015, 11:38 AM   #1
Go Seahawks!
Subsailor's Avatar
Question to dealer about weight issue on 2013's
Hello again. I am working with the dealer on the final parts of my purchase of the 2013 390RB. My final issue may be my biggest and one that will cause me not to buy the coach until it is fixed. From my reading I understand that 2013s had a weight issue that is only fixed with the "275" tires and new front air bags. So, If I have the smaller tires (forget what they are) and if it has not been fixed, the coach has that very issue right? I have read that it is about a $6000.00 fix and that is not something I want to take on. Is there any other way to tell if this coach has the weight issue and it has not been fixed? I know there is something to do with the "yellow sticker", but not sure I understand that part. Thanks, Glenn
Subsailor is offline   Reply With Quote
Old 11-14-2015, 12:33 PM   #2
I-RV's Avatar
Glenn
You don't have to open multiple threads on the same subject. Having 275 tires means you do not have to run the 255's at their 110lb max. limit. The tires and air bags get you a re-certified front axle at 12,000lbs (originally 10,410lbs). The rear axle is 17,500lbs, so you have a total of 29,910 lbs carrying capability. Since the Allison 2500mh tranny limits you to 33,000 lbs, that is your GCWR for motorhome and toad.
A full load of fresh water adds 720 lbs alone. Yes, you want the seller to tell you what the door's yellow sticker says. But it has not always been true, so the least the dealer can do for you is drive it down the road to a truck stop and get a CAT weighing.
You are in the driver's seat when buying or negotiating when on a telephone. Sitting in the seller's office, you are not.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-14-2015, 12:45 PM   #3
Go Seahawks!
Subsailor's Avatar
Originally Posted by I-RV View Post
Glenn
Hank
Sorry Hank, I did not realize I had asked this question before, a lot going on and the information I am finding here has proved invaluable. I won't post anything else about this issue and hope I can just learn from what I read. -Glenn
Old 11-14-2015, 01:26 PM   #4
accumack's Avatar
Forest River for some of us have replaced the airbags and tires at their expense. We are original owners I don't know if they will do it for free for second owners but I suspect they would. Mine is being done this week.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-14-2015, 02:31 PM   #5
Go Seahawks!
Subsailor's Avatar
I just found out that the coach has the 255 tires on it, so...no upgrade has been accomplished. I just called and told the dealership that if it's not corrected I am not going to purchase the coach. I hope they do the right thing, we really like it.
Old 11-14-2015, 02:55 PM   #6
I-RV's Avatar
You are now in the driver's seat. You don't just want tires; you need the front axle upgrade. I'm sure that FR will do it, but let your dealer get the approval. Even if approved and it is not done before purchase, you need to get it stated on the purchase document.
Hank
Old 11-14-2015, 04:07 PM   #7
Campin Cajun's Avatar
I thought this issue was a "free" fix??
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-14-2015, 04:34 PM   #8
Go Seahawks!
Subsailor's Avatar
I certainly hope it is Cajun and the dealership takes care of it.
Old 11-14-2015, 09:38 PM   #9
Name:	ImageUploadedByForest River Forums1447558656.834815.jpg
Rhouser@forestriverinc.com
Right this number down.
Old 11-14-2015, 09:47 PM   #10
Subsailor I sent you a PM. Also are you one of those weirdos that used to travel around in a large coffin sneaking around the world deep under water hiding from everyone. We have one like that already. He's ok but not sure we all trust him.
2013, dealer, weight
