Old 01-25-2016, 03:39 PM   #11
mikeborny's Avatar
It started up without a problem, but low coolant light came on. Then after a minute or two, the shut engine down light came on and I shut it down. In the 40's all day and tomorrow so going to add some coolant and check tomorrow.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 01-25-2016, 03:47 PM   #12
accumack's Avatar
Is your engine block heater plugged in?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 01-25-2016, 03:49 PM   #13
1-800-FTL-HELP then #1 when prompted.
Paulie Boy is offline   Reply With Quote
Old 01-25-2016, 04:12 PM   #14
Originally Posted by Kenny kustom View Post
Get it into a warm shop asap.
Then you can see if anything has been damaged by the coolant freezing. Just let it thaw, check for leaks.
Did it start? I wouldn't try starting it with a frozen block.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I agree if the coolant is frozen in the surge tank than good chance it is also froze in the block & head. Hopefully it has only pushed out a frost plug & not cracked anything. I don't recommend starting it if frozen. Get to a warm shop & check for leaks.
Gee Force is offline   Reply With Quote
Old 01-25-2016, 05:54 PM   #15
Kenny kustom's Avatar
Did it not leave the factory with the proper mixture of antifreeze?
I'm wondering how it froze?
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Kenny kustom is online now   Reply With Quote
Old 01-25-2016, 06:00 PM   #16
mikeborny's Avatar
Good news is that the overflow was not frozen, just very low. Put gallon and a half of coolant in and plugged in block heater while gen was running for about 40 min. It took that long to get that damn cap off. How do you have the engine "high" idle?
Old 01-25-2016, 06:02 PM   #17
Good to hear!
2016 Sabre 36QBOK
Old 01-25-2016, 06:14 PM   #18
mikeborny's Avatar
Thanks for search, i was able to figure out you can high idle by using cruise control. Wanted to let engine heat up to see if i can notice any leaking from radiator.
Old 01-25-2016, 06:23 PM   #19
Good news Mike.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 01-25-2016, 06:47 PM   #20
Rock on!
Paul
2014 390 BH-60
2015 Jeep Wrangler Unltd. Sahara
