Old 09-18-2015, 08:38 PM   #1
Radiator Question
I have enclosed two pics of the radiator expansion tank on our 20213 Berkshire.
Biggest problem is the cap can not be removed due to the brace for the rear slide being almost on top of the cap.
Cap can be loosened but not removed.
Does anyone on here with a 2013 Berkshire 360Q MH have the same problem and how was it corrected?
Donnie and Linda Furkids Buddy and Rain
2013 Berkshire 360Q w/2013 Cherokee following close behind.
donie is offline   Reply With Quote
Old 09-18-2015, 09:44 PM   #2
Sorry, can't help.... But gotta say WOW!!! a marvel in engineering and design!!!
Boowho??
boowho is offline   Reply With Quote
Old 09-18-2015, 09:55 PM   #3
Kenny kustom's Avatar
Could the whole degas bottle be removed from the bracket, in order to fill?
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-19-2015, 01:26 AM   #4
Berkshire club
Berkshire Driver's Avatar
We have a 360Ql-60 and my cap can be removed but it is tight against that brace had another person from Midland tell me his was a real B to get out, it will fun if or when coolant needs adding to radiator will need a long flexible transmission funnel to get it in i have always said engineers and designers don't think anything will ever break because if the mechanics designed a coach you would have easy access to everything .
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 09-20-2015, 05:56 AM   #5
billygo3251's Avatar
Need someone with small hands. Loosen it and then let them push down and slowly position it so it can be removed. Just went through the same crap. Also get yourself a hand pumping for filling.
billygo3251 is offline   Reply With Quote
Old 01-25-2016, 03:30 PM   #6
mikeborny's Avatar
Went to start my 2014 390bh to charge batteries and had the low coolant light come on. The instructions for adding coolant attached next to radiator cap seemed long and complicated. From this thread it sounded as if you just add a gallon and good to go. Is the small tank in picture part of the coolant system? Mine was full but frozen solid.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 01-25-2016, 03:41 PM   #7
AquaMan's Avatar
That doesn't sound good. If your expansion tank froze, there's a good chance your radiator did also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-25-2016, 03:48 PM   #8
mikeborny's Avatar
On a 2014 that I bought with only 6000 miles, how could the radiator not be filled with coolant/antifreeze from factory? If FL uses fleetguard, is that not antifreeze also?
Old 01-25-2016, 03:50 PM   #9
gasman94's Avatar
Agree. I would definitely check that out.
Rich
gasman94 is offline   Reply With Quote
Old 01-25-2016, 04:34 PM   #10
Get it into a warm shop asap.
Then you can see if anything has been damaged by the coolant freezing. Just let it thaw, check for leaks.
Did it start? I wouldn't try starting it with a frozen block.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 01-25-2016, 04:39 PM   #11
mikeborny's Avatar
It started up without a problem, but low coolant light came on. Then after a minute or two, the shut engine down light came on and I shut it down. In the 40's all day and tomorrow so going to add some coolant and check tomorrow.
Old 01-25-2016, 04:47 PM   #12
accumack's Avatar
Is your engine block heater plugged in?
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 01-25-2016, 04:49 PM   #13
1-800-FTL-HELP then #1 when prompted.
Paulie Boy is offline   Reply With Quote
Old 01-25-2016, 05:12 PM   #14
2016 Sabre 36QBOK
I agree if the coolant is frozen in the surge tank than good chance it is also froze in the block & head. Hopefully it has only pushed out a frost plug & not cracked anything. I don't recommend starting it if frozen. Get to a warm shop & check for leaks.
Gee Force is offline   Reply With Quote
Old 01-25-2016, 06:54 PM   #15
Did it not leave the factory with the proper mixture of antifreeze?
I'm wondering how it froze?
2016 Sabre 36QBOK
Old 01-25-2016, 07:00 PM   #16
mikeborny's Avatar
Good news is that the overflow was not frozen, just very low. Put gallon and a half of coolant in and plugged in block heater while gen was running for about 40 min. It took that long to get that damn cap off. How do you have the engine "high" idle?
Old 01-25-2016, 07:02 PM   #17
Good to hear!
2016 Sabre 36QBOK
Old 01-25-2016, 07:14 PM   #18
mikeborny's Avatar
Thanks for search, i was able to figure out you can high idle by using cruise control. Wanted to let engine heat up to see if i can notice any leaking from radiator.
Old 01-25-2016, 07:23 PM   #19
Good news Mike.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 01-25-2016, 07:47 PM   #20
Rock on!
Paul
2014 390 BH-60
2015 Jeep Wrangler Unltd. Sahara
