Old 05-24-2016, 09:29 PM   #1
Marine
Radio Rocker Switch Problem
I am new to the forum. I purchased a used 2014 400BH. When I push the dash radio rocker switch to listen to the radio without the key in the ignition, it adversely affects several other circuits. My leveling jacks are powered up, the night shade doesn't function, the outdoor awnings don't work,and the front tv doesn't work. This can't be the way it should function. Has anyone experienced this or have any input? Thanks.
Marine is offline   Reply With Quote
Old 05-24-2016, 10:40 PM   #2
I have never experienced this problem and quite honestly I have always wondered what that radio switch does. My radio works fine with the switch on or off.
My simple solution would be to leave the switch alone....
If you want to listen to the radio when parked .... switch your entertainment unit to tu
lefaivre is offline   Reply With Quote
Old 05-24-2016, 10:43 PM   #3
Sorry hit enter by mistake ....
Switch entertainment unit to tuner or radio setting ... this will solve your problem and result in much better sound since it will go thru surround sound and subwoofer
Old 05-25-2016, 07:59 AM   #4
Marine
What type of motorhome do you have? What does your radio switch do when you push it? Can you listen to your dash radio when you do not have your ignition key turned on?
Old 05-25-2016, 11:37 AM   #5
If the key is in the ignition most if not all you describe happens. Remove the key and try again.
2015 XL 40QL
Paulie Boy is offline   Reply With Quote
Old 05-25-2016, 11:56 AM   #6
15berkxl's Avatar
2015 XL 40QL
Paul doesn't the key have to be on or in accessories for all that to happen. Just having the key in the ignition I wouldn't think would do anything.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 05-25-2016, 12:16 PM   #7
Fulltime in our Berkshire
KennyGolub's Avatar
If I'm not mistaken on the rocker switch allows you to play the
In dash radio without a key in the ignition
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 05-25-2016, 12:24 PM   #8
Rocker Switch for Radio
In my Berk it allows me to listen to the dash radio with the coach off.
Pmorris is offline   Reply With Quote
Old 05-25-2016, 12:24 PM   #9
Marine
Thank you for your responses. Please note that all of the circuit issues are occurring without the key in the ignition. Can anyone tell me how their in dash radio rocker switch works? Again, I have a 2014 Berkshire 400 BH. Thanks.
Old 05-25-2016, 12:41 PM   #10
tmmar's Avatar
If you push the rocker switch (down I think) and the light on the switch goes on, that will turn the radio on and you can listen to the dash radio without having to use the ignition key.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
radio
