AV1, rear view camera, is configured to be the primary camera unless the blinker triggers the left and right cameras. There is a button to cycle through the cameras located on the extended screen. Try cycling through the cameras. Otherwise, press and hold the "picture" button to access the on/off switch for the cameras. Maybe your AV1 was somehow turned off. Hope this helps
