Old 01-12-2014, 07:15 PM   #1
RKC02's Avatar
Rear furnace blowing cold
Had a hard time staying warm driving today and now parked and hooked to shore power. Front furnace is working well but rear only blowing cold air. Have tried setting thermostat to max to no avail. Obviously LP is working or front would not be working (right?).
Anyone have any idea how to get the rear furnace working? I am also assuming that both furnaces can run at the same time - hoping that's a good assumption.
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 01-12-2014, 07:33 PM   #2
Ford Idaho's Avatar
What are the current settings of the rear thermostat?
Old 01-12-2014, 07:37 PM   #3
RKC02's Avatar
85 degrees right now
Old 01-12-2014, 07:43 PM   #4
Ford Idaho's Avatar
Fan speed?
Old 01-12-2014, 07:45 PM   #5
RKC02's Avatar
Auto. Whenever i select low, med, or high fan speed the A/C fan starts running (?)
Old 01-12-2014, 07:46 PM   #6
RKC02's Avatar
I set the rear furnace same as front
Old 01-13-2014, 04:24 PM   #7
I had that problem and went to elec compartment outside and pulled the fuse to the furnace. It seemed like it didn't know what to do,so this reset it and it worked.
Mike
mcomer is offline   Reply With Quote
Old 01-13-2014, 06:12 PM   #8
RKC02's Avatar
Mike, i pulled the fuze, waited about a minute and reinserted. No change. The furnace was turned off at panel. Did you do anything different?
Old 01-13-2014, 08:19 PM   #9
No, I actually pulled the front and rear. They are 10 amp fuses if I remember, and it just started working correct. I didn't know what else to do, good luck.
Mike
Old 01-14-2014, 10:56 AM   #10
Mmnsc's Avatar
Do you have a Dometic thermostat? Have you tried to reboot the thermostat? There is a rebooting procedure in the owners manual. Hopefully that might help. God luck
Mmnsc is offline   Reply With Quote
furnace
